3 Wire 220 V Dryer Plug/ Cord - Appliances - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 01:52 PM   #1
3 wire 220 v dryer plug/ cord
which one of the wires is positive which is negative
snommel is offline   Reply With Quote
Old 07-17-2011, 02:02 PM   #2
Sparky
Rewards Points: 510
no such thing as positive or negative in a 240V system.
Black or red are your hots(doesn't matter), white is a neutral.
Techy is offline   Reply With Quote
Old 07-17-2011, 03:02 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
if you ask a question like that you probably should not be messing with it
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 07-17-2011, 03:42 PM   #4
Rewards Points: 1,016
Two of the wires are called the hots - they are both negative and/or positive - as they are opposite in phase.
Here's an explanation:
http://www.nojolt.com/Understanding_...circuits.shtml
____________
Vince
Installing Switch In Reversing AC Motor RetiredLE Electrical 18 10-26-2014 10:51 PM
removed old romex (added new wire) and added a plug doesn't work now? Limit54 Electrical 9 11-08-2009 09:03 PM
New Dryer Cord Required? sweaty Electrical 6 04-12-2009 11:23 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Ele hot water tank and welder sharing circuit wazeaz Electrical 68 03-19-2008 07:17 PM
