Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-27-2009, 11:54 PM   #1
3 way switch
I have my lights in my tiny garage wired on a 3 way switch...If you turn one switch on the other switch does not work, and vise versa. what is causing this..The stupid electrician that i used a long time ago wired the switches with a 2 wire. used the neutral as one of my travelers.. and i replaced both switches and same problem...did my neutral short out or what is the problem??
thanks
Tradesman14 is offline   Reply With Quote
Old 09-28-2009, 01:04 AM   #2
GetYourShineBox's Avatar
3 way switch
3 way switch
GetYourShineBox is offline   Reply With Quote
More On This Topic
Hi! My name is Adolph Ramirez from Tampa, Florida on behalf of Expert Village, this is how to install a ceiling fan. Make sure you disconnect all of your power; shut it off at the service panel. Don't rely on any kind of switches or anything like that... Read More »
Hello! My name is Mac and on behalf of expertvillage.com I am here to discuss MIG welding. Today we are going to talk about troubleshooting problems with the MIG welding machine. Now, unlike a stick welding machine that is really very simple to operate... Read More »
Michael Raines, Expert Village. So, let's get right into installing our X10 system. We're going to put in a wall switch. So, let's get to it. This is your everyday wall switch. Semi modern rocker switch, kind of nice but it's not remote control and it's... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman; basically an electrician. I'm here today with expertvillage.com and we are hanging a ceiling fan in this house. Now we've already been through all the steps of shutting the power off... Read More »
Construction and home repair are two industries where contractors are constantly scrutinized. However, it is usually with good reason. There are numerous contractors working in the field who have no problem charging customers extremely high prices for... Read More »
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
