240 V 10 Amp Stove Top. (Kenyon) - Appliances - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 10:59 AM   #1
240 v 10 amp stove top. (Kenyon)
What wire and what breaker do I use to connect this stove top.
This is in a Motor home.
Girwin is offline   Reply With Quote
Old 04-21-2012, 11:35 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Need a make and model on the stove. Very unusual to have an electric stove in a motor home.
Coastal South Carolina
Old 04-21-2012, 01:26 PM   #3
Two Burner Caribbean Cooktop, 240V Model B41602 (made for boats) Not any more some coachs are now all electric.
Old 04-21-2012, 01:39 PM   #4
A "Handy Husband"
rjniles's Avatar
Specs listed below
You could wire hard wire that with 14/2 (with ground) cable on a 15 amp 2 pole breaker.
Specifications Volts: 240 Volts Amps: 10 Amp 6-1/2" Burner: 2 (1,200 Watts) Hard Wired: Yes Dimensions Overall Width: 21" Overall Depth: 12" Overall Height: 2 5/8" Cutout Width: 20" Cutout Depth: 10 3/4"
Be advised that not a RV parks have 50 amp, 240 volt service.
Old 04-21-2012, 01:44 PM   #5
Thanks but I belive I will use 12/2 (with ground) cable on a 20 amp 2 pole breaker. I know not all parks have 50 amp serive but I will not need to worry about that as I belong to a park system with all parks having 50 amp service.
Thanks again
girwin
Old 04-21-2012, 02:27 PM   #6
A "Handy Husband"
rjniles's Avatar
12/2 with 20 amp is fine.
Also noticed that unit comes in a 120 volt model (uses 20 amps) that might be more universal.
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 10:30 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 06:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
