Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-11-2009, 10:54 AM   #1
1981 GE Medallion Electric Wall Oven Repair / Tune-up
I have an older GE Medallion wall over (Model # J 53 AS-4) which needs a new light switch (door, push type) and door gasket / seal.
I have come across many switches but haven't seen any that are 1A / 4A. I imagine it is 1A @ 110V and 4A @ 220V. Anyone know where I can find a compatible switch?
I'm at a loss trying to find the door gasket. So any info on this part would be helpful as well.
Reilley is offline   Reply With Quote
Old 01-11-2009, 07:29 PM   #2
Reiley, You want to find an old GE service centre or look at the switch for supplier info. In 1981 most switches GE used were likely US or Canadian
See if you can find out if that range was mde under different lables, ie Kenmore, Viking from Eatons, etc. Was it GE Canada or US? This may help you track it down. The switch was likely not exclusive to that range.
Chemist1961 is offline   Reply With Quote
Old 01-11-2009, 11:14 PM   #3
It probably is a Canadian built oven...I don"t recognize the model number and I was working for GE in 81...
GE JIM is offline   Reply With Quote
Old 01-11-2009, 11:16 PM   #4
Check with Applianceaid.com.....
Old 01-18-2009, 11:25 AM   #5
Thanks for the replies. My subscription emails don't seem to be working so I nlost track of this thread.
It is a Canadian model. I can't get any hits on the model number online. I will check w/ my local GE service centre.
Old 01-18-2009, 01:10 PM   #6
Reilly if that swicth is accessable, take a photo and list the markings, dimensions. Someone here will likely recognise it. Given the age it will likely be something common on other brands in North America. Maybe post a shot of the oven as well in case there is a similar model out there built in the US.
I.E. Kenomre in todays items, may have a model abc123 that is identical to a Frgidaire 77777 but they don't have to price match on private label.....because they can say it's not the same model so they make full markup.
Wall oven rusty_5620 Electrical 6 03-15-2007 02:18 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
