10+ Maytag Washer Oil Leak. LAT2300AAE - Appliances - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 05:58 PM   #1
Mike K
Rewards Points: 83
10+ Maytag washer oil leak. LAT2300AAE
Hello.
My trusty Maytag, or so I thought, has some oil underneath it. The oil wasn't running out in front of the washer, but soaked the dust and lint which collects underneath.
I assume its a bad transmission seal. But wouldn't that also mean a loose bearing/bushing?
Is it worth repairing a 10+ year old Maytag?
rebar is offline   Reply With Quote
Old 05-31-2011, 08:09 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
very typical, if it is just a little oil it will be no problem. If it starts to run out, then you have a problem that will need to be repaired.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-31-2011, 09:31 AM   #3
Mike K
Rewards Points: 83
I found soil soaking all the dust under and behind the washer. Not just a little spot.
I found the lip seal part #436000. Do I need the Lip Seal Tool Kit (part #430588)to install it? What other parts would I need to complete the job, and when will I know its time?
Thanks for your time hardwareman.
Old 05-31-2011, 12:03 PM   #4
#1 HAWKEYE FAN
you will definetly need the tool, thats a good washer so go ahead and just do it soon.
Old 05-31-2011, 12:27 PM   #5
Mike K
Rewards Points: 83
Just talked to my local Maytag to get a idea of price. They said they dont replace the seal and only replace the tranny $300. Also said the lip seal is for the top keeping the water in. ?
Old 05-31-2011, 02:18 PM   #6
#1 HAWKEYE FAN
PART # 207843 lip seal kit for center shaft on trans. costs about $10.00
Air injector broken -- Maytag topload washer TryHard Plumbing 18 07-17-2015 07:47 PM
maytag washer makes banging noise atechdrew Appliances 1 04-25-2011 08:38 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
Washer on/off drain leak opper3 Plumbing 1 03-02-2009 05:06 AM
Maytag Washer and GFI mwarken Appliances 3 12-09-2008 03:22 PM
