-   -   10+ Maytag washer oil leak. LAT2300AAE (http://www.diychatroom.com/f47/10-maytag-washer-oil-leak-lat2300aae-106055/)
rebar 05-30-2011 06:58 PM
Hello.
My trusty Maytag, or so I thought, has some oil underneath it. The oil wasn't running out in front of the washer, but soaked the dust and lint which collects underneath.
I assume its a bad transmission seal. But wouldn't that also mean a loose bearing/bushing?
Is it worth repairing a 10+ year old Maytag?
hardwareman 05-31-2011 09:09 AM
very typical, if it is just a little oil it will be no problem. If it starts to run out, then you have a problem that will need to be repaired.
rebar 05-31-2011 10:31 AM
I found soil soaking all the dust under and behind the washer. Not just a little spot.
I found the lip seal part #436000. Do I need the Lip Seal Tool Kit (part #430588)to install it? What other parts would I need to complete the job, and when will I know its time?
Thanks for your time hardwareman.
hardwareman 05-31-2011 01:03 PM
you will definetly need the tool, thats a good washer so go ahead and just do it soon.
rebar 05-31-2011 01:27 PM
Just talked to my local Maytag to get a idea of price. They said they dont replace the seal and only replace the tranny $300. Also said the lip seal is for the top keeping the water in.:huh: ?
hardwareman 05-31-2011 03:18 PM
PART # 207843 lip seal kit for center shaft on trans. costs about $10.00
