Wont Run After Doing Head Gasket - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-26-2010, 11:11 PM   #1
liscenced electrician
Rewards Points: 538
wont run after doing head gasket
Just finished up doing a head gasket on a 94 3.4l v6 camaro. After we got it all back together and tried to start the car, it ran absolutely terrible. Shook really bad and didn't want to idle. We double, triple and quadruple checked the firing order and everything is in the right order. Started pulling spark plug boots off and when we pulled the #3 cylinders spark plug boot off it ran the same without that cylinder. We pulled that cylinders spark plug, put the boot on the spark plug and touched the electrode to ground and its getting spark. My buddy thinks its that cylinders injector. The exhaust is smoking some and smells like unburned fuel.
my questions are
1: Would it run as rough as it is with only 1 cylinder not firing?
2: Any ideas of what i should try?
jimmy21 is offline   Reply With Quote
Old 09-27-2010, 07:53 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
If your exhaust smells like gas i would check MAF and O2 sensors
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-27-2010, 08:01 AM   #3
47_47's Avatar
Rewards Points: 44
Try swapping the plugs and then the injectors, see if the miss follows either. Make sure you lube the injector 'o' rings with engine oil when installing. If no change do a compression and a cylinder leak down test.
47_47 is offline   Reply With Quote
Old 09-27-2010, 09:27 AM   #4
Rewards Points: 152
Any chance the dist is 180deg off?
burnt03 is offline   Reply With Quote
Old 09-27-2010, 02:11 PM   #5
Rewards Points: 538
it doesn't have a distributor. It uses coil packs
today i pulled all the spark plugs out and half of them looked wet and fouled and so i replaced those and it ran a tiny bit better. It would at least idle, but still VERY rough. Any ideas what i should try?
Could bad injectors make it foul plugs? Don't bad injectors make it starve for fuel?
Old 09-27-2010, 02:52 PM   #6
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
wet plug can be a sign of a coil not firing. leaking injectors could cause wet plugs i'd imagine
Old 09-27-2010, 04:16 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
not if they are stuck open. Then they spray when they aren't supposed to.
Old 09-27-2010, 06:21 PM   #8
Rewards Points: 538
on half the cylinders?
Old 09-27-2010, 06:55 PM   #9
the Musigician
DangerMouse's Avatar
I had a similar problem.... it was the coil pack.
DM
Old 09-27-2010, 07:30 PM   #10
nap
You talking to me?
nap's Avatar
it was merely an answer to the question asked. if it is applicable or not here, I made no commitment.
as DM stated, I would look to the coils.
Old 09-27-2010, 07:43 PM   #11
Rewards Points: 538
i don't think its the coil pack because it was working before and we tested to see if they are sparking.
I've decided its probably fuel injectors crossed up. This would completely make sense and completely possible from when we put them on that we didn't get them right. We basicly made an educated guess on where they went. Problem is now i don't know where to find which injectors go where. I didn't find it in the haynes manual
Old 09-27-2010, 08:48 PM   #12
nap
You talking to me?
nap's Avatar
what do you mean; you mixed them up. the injectors are the same. If you mean the wires that connect to them, that's different.
are the wire colors going to all injectors the same?
Old 09-27-2010, 11:35 PM   #13
Rewards Points: 538
i ended up finding cylinders marked on the injector wires and they were correct
I took it to an auto mechanic. He took 1 look at it and swore the plug wires were totally farked up. He switched 2 and it all of the sudden it would idle. He said 2 more are still crossed. Doesn't make sense to me, because we traced those wires out at least 5x. But if he can make it run smoothly, more power to him
Clipped Head v. Full Round Head Nails RickT Carpentry 10 11-18-2010 10:00 AM
Handheld shower in addition to fixed head OnTheGo Plumbing 4 03-25-2010 12:31 AM
Head Gasket Leaking pjm Automotive Repairs 11 01-25-2010 08:10 AM
Bad head gasket on 98 civic? dbldee20 Automotive Repairs 5 02-19-2009 08:14 AM
Head gasket? DIY? 98 grand prix 3800 papashaq Automotive Repairs 3 03-18-2007 09:38 PM
