Wobbling After New Tires - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-11-2010, 01:20 PM   #16
47_47's Avatar
Rewards Points: 44
A few items to check.
Drive at 65 with a chase vehicle. Have an occupant of the other vehicle look at your front wheels. You will see a front tire bounce aggressively if there is a bad strut.
Re-check balance of front wheels. If you have steel rims, they may have bent one when installing the new tires.
The bead of the new tires may not be fully seated on the rim (especially with stiff side wall tires).
Tires and rims both have heavy spots. Deflate the tire, break the bead loose from the rim and rotate the tire 180 with respect to the rim. Re-inflate, re-balance and test.
Your van has floating front brake rotors and the wheel lug nuts secure them to the hub. The rotors may have become separated from the hub allowing rust particles to get between the rotor and hub. This will cause excessive runout and a possible vibration. If this is the case, you may also experience a brake pulsation.
47_47 is offline   Reply With Quote
Old 10-11-2010, 07:28 PM   #17
Bigplanz's Avatar
Rewards Points: 912
Probably an unbalanced tire, but you might want to check the tie rods. Jack up the car, put the key in the ignition and the van in 'run' to unlock the steering, and then grab the wheel in the 3 and 9 o'clock position. Pull back and forth. Any movement in the tie rods means they need to be replaced. The whole wheel might move, but if there is play/slop where just the tie rod moves, it's probably bad. Check to see if the boots are firm. If not, you need to grease them up.
Bigplanz is offline   Reply With Quote
Old 10-11-2010, 08:03 PM   #18
Rewards Points: 1,010
Funny you should mention that. The front tires went bad because one of the tie rods eventually came out. The tie rod that came out was replaced, and I had them triple check the other tie rod.
The funny (and scary) thing is that I didn't feel any wobbling as the tie rod worked itself out over time. Fortunately it finally came out as I was pulling out of a driveway and going slow, and not while I was on a highway. My van started jerking as if I was hitting potholes, yet the road was smooth. I turned around and pulled back into the driveway just in time for the rod to fall out.
What's even odder still is the tie rod didn't shear or break, it simply unscrewed itself. The neighbor who looked at it, the tow truck driver who towed it, and the mechanic who worked on it all said they have never seen that happen.
spaceman spif is offline   Reply With Quote
Old 10-11-2010, 08:15 PM   #19
Rewards Points: 152
Eh? A tie rod worked itself SO loose that it actually fell out and you never noticed til it fell out? And what fell out exactly? The end in the knuckle I presume. Or did the inner separate from the outer? Irrespective of that...these are critical facts left out from the beginning.....any other essential facts you haven't shared?
piste is offline   Reply With Quote
Old 10-11-2010, 08:24 PM   #20
Bigplanz's Avatar
Rewards Points: 912
You must have lost the cotter pin on the castle nut. That's the only way it could unscrew, and, of course, the reason there is a cotter pin in the first place.
I have seen most tie rod failure during low speed sharp turns. Ford Taurus' used to be notorious for this sort of catastrophic failure. People turning into a parking space and BAM! the tie rod breaks like a gun going off. Very spectacular when the wheel falls off a four year old car in the parking lot. I saw a tricked out SHO that had this happen in a Wal-Mart once. Guy was piiiiiiisssssed!
Old 10-11-2010, 08:39 PM   #21
The jam nut was loosened and backed off and the inner rod simply unscrewed itself. But no visible damage to the nut, no visible damage to the rod. And like I said, before the day it fell apart, no wobbling, no pulling, no vibration, no bouncing. Which is why I'm concerned because now I feel wobbling.
My suspicion is when I had the front tires replaced at a local dealer a little over a year ago, whoever did it did something wrong when they did the alignment. But you can't take it back and say "You installed these wrong one year ago."
Old 10-11-2010, 08:51 PM   #22
Bigplanz's Avatar
Rewards Points: 912
Wow. I've never heard of an inner tie rod unscrewing itself from the rack assembly. That's wild.
Old 10-11-2010, 09:10 PM   #23
Rewards Points: 152
Umm...your original post said you had the front tires replaced "recently"...and now you say a little over a year ago....? You had them replaced twice?
I'm no master mechanic but AFAIK it would be VERY obvious if the inner and outer rods unthreaded by a handful of threads or so....but to have absolutely zero noticeable effect until the inner and outer fully separated....I just don't see how that can happen. But taking it on face value....it makes the ENTIRE steering assembly suspect as the cause of your current wobbling. But I still go back to road force balancing as my first recommendation.
Old 10-11-2010, 11:18 PM   #24
I had my front tires replaced a little over a year ago. The tie rod fell off recently with that set of tires, and I'm now suspicious they did something to the tie rod assembly when they installed and balanced the tires. When I took the van into a different shop to fix the tie rod, they pulled the front tires and I could see the inner tread had worn unevenly, so I had them replace the front tires at the same time they fixed the tie rod. They also balanced and aligned them, and now I feel a wobble at 65 mph. Sorry if that wasn't clear at first.
And for all I know, the tie rod might have been fine until the day it popped out. But believe me, I can feel when something isn't right with my van, and there was no pulling or wobbling.
Old 10-11-2010, 11:19 PM   #25
I couldn't believe it either. None of the mechanics had ever seen anything like it either. The tow truck driver was shocked, too. When he saw it, his first question was "Do you have any enemies??"
using concrete filled tires for posts rescrewableE Building & Construction 3 04-16-2010 06:22 PM
Small pneumatic tires not holding pressure Nestor_Kelebay Automotive Repairs 14 04-26-2009 09:39 AM
Band Saw tires collosse Tools 6 01-02-2009 08:45 PM
wanna start mounting tires myself amakarevic Automotive Repairs 6 07-31-2008 08:37 PM
