Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-07-2012, 10:24 PM   #1
Wiper washer
How difficult is it to replace a defective windsheild washer pump on a 1999 Isuzu Rodeo?
dfiddler is offline   Reply With Quote
Old 04-08-2012, 04:10 PM   #2
ukrkoz's Avatar
Wiper washer
pumps are usually inside the washer fluid canister. remove canister, pull pump out. unless you have some very different design.
ukrkoz is offline   Reply With Quote
Old 04-08-2012, 08:38 PM   #3
Wiper washer
Thanks for the reply. This is formerly my wife's car, now she's got the n one and I get hers. It has "never" worked according to her. All the fuses are ok so I am assuming its the pump. Could it be something else?
Old 04-08-2012, 09:39 PM   #4
ukrkoz's Avatar
Wiper washer
anything from fusible link to rusted connector. Pull pump out and try it off battery. If it works, then it's somewhere in wiring. Switch.
The Following User Says Thank You to ukrkoz For This Useful Post:
dfiddler (04-08-2012)
Old 04-08-2012, 09:47 PM   #5
Wiper washer
Thanks a lot. Can't do worse than right now.
Draining laundry sink into washer stack? glamgirrl Plumbing 33 12-31-2011 03:02 PM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 03:41 AM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 02:01 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General Discussion 3 08-23-2009 06:29 PM
