Wiper Arc Way Less Than 90 Degrees - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-28-2012, 08:40 AM   #1
Rewards Points: 1,062
Wiper arc way less than 90 degrees
People,
Have a 95 Voyager van, and now the arc for wipers is way les than the typical 90-120 degrees. recently worked on motor- I replaced the "washer" thingy gismo, old one rotted off. It he3ld the levers on place, thats all. Not sure if that did something. So now, with wipers off, they rest at about 35 degres off horizontal (resting point).
They stick up during driving, however, not dangerously blocking view. And when activated, they only wipe an arc of about oh, 70 or so deg.What hapened?
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 11-28-2012, 09:02 AM   #2
Rewards Points: 6,652
Slipped. Take off the nut that holds the arm, move them a couple notches, tighten the nuts, try. If too far, move just a tad back down, repeat.
The Following User Says Thank You to gregzoll For This Useful Post:
noquacks (11-28-2012)
Old 11-28-2012, 12:00 PM   #3
47_47's Avatar
Rewards Points: 44
Park the motor. Loosen the nut at the pivot and set the blades to the correct position. Tighten the nut.
47_47 is offline   Reply With Quote
The Following User Says Thank You to 47_47 For This Useful Post:
Old 11-28-2012, 07:39 PM   #4
OK, guys. will try it......thanks.
Condensation in middle of window byon49 Windows and Doors 2 10-30-2012 01:26 PM
window condensation kmpittman Windows and Doors 4 11-29-2011 10:10 AM
sweating double pane windows etch Windows and Doors 6 10-31-2011 10:30 PM
Condensation amyevans Windows and Doors 6 10-21-2011 11:11 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
