Window Motor - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-02-2013, 03:10 PM   #1
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 92
window motor
Anyone ever change a window motor on an '85 econoline? Just wondering if the regulator has to come out. Some years they do, some they don't. The regulator is installed with rivets. I hate drilling those out.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-02-2013, 03:22 PM   #2
A number if years back I did my '91 and didn't have to take out regulator. I think the body styles were the same till '92.
But that's been a while back and my memory of it's a little dim. I know watcha mean about them dang rivets
RoyalAcresRod is offline   Reply With Quote
Old 09-02-2013, 03:38 PM   #3
Rewards Points: 92
That's what I keep running into. The Haynes book has nothing on it. And some people say it has to come out, some say it doesn't. Would like to know before I tear it down. It's a custom van, all kinds of stuff to take off just to get the panels off, and I have to get it done in one day.
Old 09-02-2013, 04:20 PM   #4
Best up just get to it and have your drill and bit ready to go!
Old 09-02-2013, 05:43 PM   #5
Rewards Points: 92
Probably what I will do. A tree fell on my car a couple months ago, so this is my work truck and daily driver.
Old 09-03-2013, 02:37 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,286
Don't they sell the rebuild kits with the replacement gears? I seem to recall they are like $8.
Old 09-03-2013, 03:36 PM   #7
Rewards Points: 92
A gear kit is $20, but you still must pull the motor. And a new motor is only $46. with gears.
Old 09-03-2013, 07:52 PM   #8
ukrkoz's Avatar
Rewards Points: 946
  1. Disconnect the battery ground.
  2. Remove the door trim panel.
  3. Disconnect the window motor wiring harness.
  4. There are 2 dimples in the door panel, opposite the 2 concealed motor retaining bolts. Using a 1 / 2 in. drill bit, drill out these dimples to gain access to the motor bolts. Be careful to avoid damage to the wires.
  5. Remove the 3 motor mounting bolts.
  6. Push the motor towards the outside of the door to disengage it from the gears. You'll have to support the window glass once the motor is disengaged.
  7. Remove the motor from the door.
  8. Installation is the reverse of removal. To avoid rusting in the drilled areas, prime and paint the exposed metal, or, cover the holes with waterproof body tape. Torque the motor mounting bolts to 50-85 inch lbs. (6-10 Nm). Make sure that the motor works properly before installing the trim panel.
ukrkoz is offline   Reply With Quote
Old 09-03-2013, 08:06 PM   #9
Rewards Points: 92
I'll try it, but on a Ford like mine, step 3 is impossible until the motor is loose. You can not reach the wiring harness. And all three motor bolts are concealed.
Old 09-04-2013, 08:24 PM   #10
ukrkoz's Avatar
Rewards Points: 946
Get a friend with small hands to disconnect wiring. Also, this was for 1500 Econoline. They have 2 more models, I just wild guessed.
Old 09-06-2013, 09:51 AM   #11
Rewards Points: 92
No dimples. Just lots of rivets. Don't know which ones too drill out.
Old 09-06-2013, 01:10 PM   #12
Rewards Points: 92
Where did you find the diagram?
Old 09-06-2013, 09:46 PM   #13
ukrkoz's Avatar
Rewards Points: 946
sign up with autozone account, it's free. you will have access to repair manuals.
now, my serious advice is - if you plan on keeping this car for any extended period, sign up for DIy account with Alldata. That's what pros use for repairs in shops. DIY account is 40 bucks for 5 years. That's, mi amigo, EIGHT DOLLARS a year. Nothing.
Also, comes with support. You miss something - you dial a number, or send email, they fetch it for you.
Old 09-06-2013, 09:47 PM   #14
ukrkoz's Avatar
Rewards Points: 946
http://www.alldata.com/
http://alldatadiy.com/
ELectric motor issue RWolff Electrical 23 06-22-2013 12:41 AM
General window install questions miamicuse Windows and Doors 9 04-23-2013 08:05 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
