Why Is My Front Left Wheel Slanting Inwards? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-24-2012, 09:13 PM   #1
Rewards Points: 335
why is my front left wheel slanting inwards?
I have a 97 Jetta, GLS, 5 speed, 2.0
I recently finished installing ball joints, outer tie rods, wheel bearings, and wheel hub assemblies to both the right and left front wheels.
Upon putting everything back together, the right side of the car looks, and sounds fine when driving. As for the left side (drivers side) that's a different story. I was backing out of the drive way and the wheel started squealing really loud. (Same sound as the brake sensor grinding on the rotor). Then when I got out to look to see what that squaling was, I noticed the drivers side wheel was slanted inwards really bad. (top of the wheel is slanted in wards, really bad). I checked the lug nuts as well as all connections, and everything is tight and snug.
I am going to remove the brake caliper and check to see what I can see there but why did the wheel slant in??????? what can cause it?
I was just going to take it out for a test drive to make sure I felt nothign funny. The alignment will need done. The car won't be driven until the alignment is fixed. Not sure if the alignment will change things. But I still have to get it to the shop to do.
crankbait09 is offline   Reply With Quote
Old 06-24-2012, 11:16 PM   #2
Alignment will fix everything. Your camber sounds like it is way out of adjustment.it all went out of align when took apart your steering knuckles from the struts.
renoit is offline   Reply With Quote
Old 06-25-2012, 12:07 AM   #3
(the original)
Rewards Points: 756
Is the ball joint installed correctly to the control arm?
Spindle nut torqued properly?
ratherbefishin' is offline   Reply With Quote
Old 06-25-2012, 08:52 AM   #4
I'm Your Huckleberry
Rewards Points: 2,270
I had to have a different camber "kit" (nut) installed on my F250 to prevent the bottom of the wheel slanting inwards, top was bowed out. Had to have it done at the same time I had outter tie rod ends installed an an alignemnt.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 06-25-2012, 12:54 PM   #5
Rewards Points: 335
I know I need the alignment but I am hearing that I SHOULD NOT drive this car till the alignment is completed. I don't wanna pay close to $100 for a tow to go 5 miles up the road.
How can I get this as close as good, just so I can make it to the shop? What could get ruined if I drove it the way it is?
Old 06-25-2012, 01:31 PM   #6
I'd turn the hazard lights on and go no more than 20-25 mph max and drive it there. You said it only made a noise while in reverse, so drive it forward to the shop.
Thanks.
Old 06-25-2012, 01:45 PM   #7
Rewards Points: 335
I have to try the forward thing. I was backing it out of the driveway when I heard the squealing. I pulled it back in and it was quiet.
Not sure what would happen though if I picked up speed
Old 06-25-2012, 02:42 PM   #8
I think that as long as you take it very slow and drive very cautiously you will be alright.
Thanks.
Old 06-25-2012, 07:12 PM   #9
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Yeah, if everything is tight, you should be fine to drive it 5 miles. Like Doc said, though, take it slow.
Mort is online now   Reply With Quote
Old 07-03-2012, 02:38 PM   #10
Rewards Points: 335
I loosened the strut mounting bolts and moved the wheel so that it was as close to vertical that I could get it to. That definitely did the trick. I will be taking it in for alignment this weekend. Hopefully everything checks out fine
What to do with the front of this house? Clemsig07 Remodeling 4 05-23-2011 07:57 AM
Cable Wheel - # Circuits AndrewF Electrical 6 02-10-2011 08:54 AM
Front Door Molding question queezy Carpentry 4 11-01-2010 09:35 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
thin film of oil on left front wheel bobo Automotive Repairs 15 04-11-2007 08:24 PM
