Where Does The Black Wire Go????? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-23-2009, 07:27 PM   #1
Rewards Points: 14
Where does the black wire go?????
I'm trying to figure out why my riding mower won't start, it only makes a clicking sound. Had the battery charged, starter tested fine, 15 amp fuse appears fine.
I don't know a lot about engines/mowers, but while taking apart (I did a diagram of wires, but somehow missed one) and putting back together the battery, solenoid and starter I have a black wire left over...not sure where to put it! I traced it to the starter switch. There was two black wires coming out of the starter switch, one goes down through a hold and under the engine somewhere, it's the other one that I don't know what to hook to! See attached photos.
Help!! (especially on the wire, but any suggestions on it not starting would be helpful also!)
bsmith6356 is offline   Reply With Quote
Old 09-24-2009, 06:04 AM   #2
Bigplanz's Avatar
Rewards Points: 990
Black is usually the ground wire on (American made) cars. It 'might' be a ground wire. Turn the ignition to 'run' and put a test light on it. It it lights, it's a power wire of some sort. If not, clamp the light to the (bare) black wire and touch the positive battery terminal. If the light comes on, the black is a ground wire.
Bigplanz is offline   Reply With Quote
Old 09-24-2009, 06:16 AM   #3
the Musigician
DangerMouse's Avatar
Bigplanz <-----what he said....
also, if it's just 'clicking', you may have backwards polarity.
reverse polarity and try it.
DM
Old 11-02-2009, 01:55 PM   #4
crxsleeper17m's Avatar
or set it on fire and cook some burgers
crxsleeper17m is offline   Reply With Quote
Tags
engine , lawn , mower
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-14-2009 11:17 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
Dimmer Installation rjl24 Electrical 4 02-20-2008 07:43 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
