Whats The Real Deal With Oxygen Sensors? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-28-2014, 08:27 AM   #1
Rewards Points: 1,062
Whats the real deal with oxygen sensors?
People,
Always hearing that , maybe not on all cars, but some cars need a new O2 sensor even though your car's computer/sensors do not show a code for a faulty one. Is this true, in yours opinions? Have an 01 civic, and has 125,000 miles on it, so far, original sensor. No codes yet for it have been displayed.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 06-28-2014, 08:31 AM   #2
o2 sensors get weaker over time, as long as you have no drivability issues, your fine. and yes faulty o2's may not set a code for the o2 even though the underlying cause of but not limited to, catalyst failure (sulfur smells) misfires, lean conditions (to much air), or rich conditions (to much fuel).
naes.sdrawos is offline   Reply With Quote
The Following User Says Thank You to naes.sdrawos For This Useful Post:
noquacks (06-28-2014)
Old 06-28-2014, 09:15 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,044
As long as there are within specifications and are putting out the correct voltages for the computer to adjust the fuel tables, you are fine.
Old 06-28-2014, 09:15 AM   #4
good to know, naes.
Old 06-28-2014, 09:17 AM   #5
Originally Posted by Windows on Wash View Post
+1
Thanks, wash, so One just kinda has to assume they are puting out the correct voltages if it doesnt trip a code, right? otherwise, can one measure the voltage with a meter?
Old 06-28-2014, 09:55 AM   #6
Once it is out of range, it will throw and MIL light (i.e. check engine).
No need to check it or replace it until it is failed. Some never fail.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 06-28-2014, 10:02 AM   #7
Briogaid Dearg
Rewards Points: 27
My bank 2 downstream sensor got tore off in a snow storm three or four years ago. Throws up a code every now and again, I just clear it. Passes inspections too.
Sent from my SCH-I545 using Tapatalk 2
originalhandy is offline   Reply With Quote
The Following User Says Thank You to originalhandy For This Useful Post:
Old 06-28-2014, 10:18 AM   #8
ukrkoz's Avatar
Rewards Points: 946
OP, you heard the wisdom:
DON'T FIX IT
IF IT AIN'T BROK
IF IT'S BROK
FIX IT RIGHT AWAY.
OF COURSE they want to you to believe that you MUST replace all kinds of components on REGULAR intervals. Right? Like with any "scientific research", always look who sponsored it.
ukrkoz is offline   Reply With Quote
The Following User Says Thank You to ukrkoz For This Useful Post:
Old 06-28-2014, 11:34 AM   #9
Rewards Points: 268
Huh. Never heard the 'regular maintenance' excuse for replacement of oxygen sensors before (wink wink). I've had people come in and ask about it over the years, sometimes recommended by a different dealer, sometimes by an independent shop. Since I worked for a Ford dealer, I'd show them the recommended maintenance guide (oh wow! It's in their owners manual too!) where it never mentions the o2 sensors.
The new 6 wire sensors should theoretically last forever...we shall see. They don't use external air as an oxygen reference like the 4 wire sensors do so they're completely sealed.
Marqed97 is offline   Reply With Quote
The Following User Says Thank You to Marqed97 For This Useful Post:
Old 06-28-2014, 01:35 PM   #10
Rewards Points: 254
They will get lazy over time, but as long as they are in spec any performance or economy effects will not be noticeable. I have seen cars come back though from just changing one side on high mileage cars due to the old sensor not switching as fast as the new one, which is why in school they recommend replacing all at the same time. Maybe if they were $25 a piece instead of $125
cjm94 is offline   Reply With Quote
The Following User Says Thank You to cjm94 For This Useful Post:
Old 06-28-2014, 02:21 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,452
Replacing those sensors is right up there Transmission flushes at 50K miles.....
ddawg16 is online now   Reply With Quote
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
noquacks (06-28-2014), rusty baker (06-28-2014)
Old 06-28-2014, 02:34 PM   #12
Wow, I feel much better now (wiping sweat from forehead with back of right hand)!
yeah- so many out there spread so much myths- this one, I had to run by the guys here whom I know would be looking out for me!! Thnaks, people!! Now, time to change my tranny fluid as its been a whole 6 months (sarcasm/joke).......
Old 06-28-2014, 05:38 PM   #13
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
Don't forget to change your blinker fluid and rotate the air in your tires.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-28-2014, 10:35 PM   #14
I wouldn't ever flush a transmission but I did change my toyota yaris trans fluid at 47k. It even had a drain plug. Replaced 2.6 quarts. New fluid was deep red. Old fluid a deep purple. Shifts better now.
toolaholic is offline   Reply With Quote
Old 06-28-2014, 11:47 PM   #15
Rewards Points: 254
Nothing wrong with changing trans fluid. It won't ruin a trans. If it fails afterwards there was something wrong with it. Like bad seals that sludge was sealing up.
Water comes under base of floor when it rains real hard Andrea Denise Plumbing 2 05-25-2013 11:22 PM
2 Motion Sensors to 1 Floodlight jjb82177 Electrical 8 07-04-2011 07:25 PM
Are the GAF shingles at Home Depo the real deal? Dave K Roofing/Siding 3 04-30-2011 09:04 PM
Occupancy Sensors trclac Electrical 3 10-14-2010 12:14 PM
Need some real help from a real forum:Ditra Question K.M.G Flooring 17 04-11-2010 12:03 AM
