Weird brake issue
I'll agree with "Yoyizit", as far as taking it to a dealer. IMO-what you need is a good front end/brake mechanic, and not a chain store outfit. Ask around to see if anyone knows of a local shop which specializes in brakes/front-end alignments. Try to stay away from tire stores which do this on the side. I work at an auto-parts store part-time and that is not a year/model specific item that rings a bell which we sell and re-stock often. It could be disc brake dust and the service tech is blowing out the brakes/rotor areas when he changes oil, but I doubt that. Then why would only the left side squeal? I'm wondering of you have a problem with the caliper not backing off as it should after applying brakes? This would keep the pads on the rotor just enough to cause this. Again, a good brake shop can measure the rotor thichness and caliper thickness. Good Luck, David
