Water Leaking On Passenger Floor - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-27-2013, 12:55 PM   #1
Rewards Points: 77
Water Leaking on Passenger Floor
I've got a 2006 Mercury Milan that is starting to leak water on the passenger floor when A/C is on. Doesn't matter if the condenser is on or not. When I turn, it makes a hissing sound. I have WeatherTech floor mats in my car and can isolate the problem to when the A/C is on. I'm pretty handy and not looking to drop over 100 just to have someone look at it.
Justins1171 is offline   Reply With Quote
Old 08-27-2013, 01:11 PM   #2
Rewards Points: 2,634
When your AC is on, humidity condenses on your evaporator coils. It drains to under your floorboards. The drain is messed up. It may (or might not be) a hose coming off the AC coil area. Might want to try to google or buy a repair manual to see how the AC is supposed to drain.
SPS-1 is offline   Reply With Quote
Old 08-27-2013, 02:16 PM   #3
47_47's Avatar
Rewards Points: 44
Drain is probably plugged. Look at the firewall. You will see either a 90 open end hose or just a short straight open end hose from the hvac box. Carefully insert a piece of stiff wire to clear the drain. Don't go in more than 2" through the firewall or you could damage the evaporator. Try not to get wet.
47_47 is offline   Reply With Quote
Old 09-01-2013, 06:32 PM   #4
Rewards Points: 77
Tried to unplug, no luck. Drain was clear. Water still continues. Thinking that the drain line is cracked or disconnected up under the dash along the firewall.
Old 09-02-2013, 06:25 PM   #5
Rewards Points: 1,062
Right- may not even be the drain!! Just experienced this on a 98 Voyager- ended up the drain/tube was perfectly fine- it was the big black box encasing the entire evaporator/cooling unit!! Chrysler is famous for it, but doesnt exonerate other brands, I figure. If the case is cracked like it was in my car, shessh- youre looking at removing the evap unit! Not sure on how to remove on your car, but usually, its a big deal- gotta remove the whole dash.
AND, that means recover the R134a, then do the ac all over again (new dryer, evacuate, new gas).
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 09-02-2013, 10:56 PM   #6
Rewards Points: 77
So if there is a "big black box" that encases the evaporator an it's cracked but the evaporator works fine, can I just patch up the box? It may sound like a simple solution to a possibly complex problem but I'm not able to invest in an A/C unit.
Old 09-02-2013, 11:26 PM   #7
Rewards Points: 254
That car has a foam seal between the box and firewall that leaks not much for parts but a lot of labor pulling dash and box. Not real DIY friendly. 6-8 hours in a shop.
cjm94 is offline   Reply With Quote
questions about floor heating water tank Hexar HVAC 7 08-10-2011 08:56 PM
First time homeowner from MD - Water Leaking from Ceiling under bathroom j_cross Plumbing 2 02-27-2010 12:37 AM
My Slant/Fin gas furnace is leaking water all over my floor! Switchvert HVAC 18 01-28-2009 10:58 PM
Basement water meter below floor level redfox1 Plumbing 5 12-10-2008 09:20 PM
