-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Water Leaking on Passenger Floor (http://www.diychatroom.com/f46/water-leaking-passenger-floor-186050/)
Justins1171 08-27-2013 11:55 AM
I've got a 2006 Mercury Milan that is starting to leak water on the passenger floor when A/C is on. Doesn't matter if the condenser is on or not. When I turn, it makes a hissing sound. I have WeatherTech floor mats in my car and can isolate the problem to when the A/C is on. I'm pretty handy and not looking to drop over 100 just to have someone look at it.
SPS-1 08-27-2013 12:11 PM
When your AC is on, humidity condenses on your evaporator coils. It drains to under your floorboards. The drain is messed up. It may (or might not be) a hose coming off the AC coil area. Might want to try to google or buy a repair manual to see how the AC is supposed to drain.
47_47 08-27-2013 01:16 PM
Drain is probably plugged. Look at the firewall. You will see either a 90 open end hose or just a short straight open end hose from the hvac box. Carefully insert a piece of stiff wire to clear the drain. Don't go in more than 2" through the firewall or you could damage the evaporator. Try not to get wet.
Justins1171 09-01-2013 05:32 PM
Tried to unplug, no luck. Drain was clear. Water still continues. Thinking that the drain line is cracked or disconnected up under the dash along the firewall.
noquacks 09-02-2013 05:25 PM
Right- may not even be the drain!! Just experienced this on a 98 Voyager- ended up the drain/tube was perfectly fine- it was the big black box encasing the entire evaporator/cooling unit!! Chrysler is famous for it, but doesnt exonerate other brands, I figure. If the case is cracked like it was in my car, shessh- youre looking at removing the evap unit! Not sure on how to remove on your car, but usually, its a big deal- gotta remove the whole dash.
AND, that means recover the R134a, then do the ac all over again (new dryer, evacuate, new gas).
Justins1171 09-02-2013 09:56 PM
So if there is a "big black box" that encases the evaporator an it's cracked but the evaporator works fine, can I just patch up the box? It may sound like a simple solution to a possibly complex problem but I'm not able to invest in an A/C unit.
cjm94 09-02-2013 10:26 PM
That car has a foam seal between the box and firewall that leaks not much for parts but a lot of labor pulling dash and box. Not real DIY friendly. 6-8 hours in a shop.
