VW Van Brake Problem - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-17-2013, 07:08 AM   #1
VW van brake problem
Hi guys.
The brake pedal on my LT35 (Sprinter) is almost on the floor before it brakes the van but the pressure when it gets there seems normal ie. don't have to press hard on the pedal.. There is almost no resistance on the way down and I'm hearing a slight clonking noise but not all the time.
Pads and discs are good and I had an issue with the handbrake shoes locking up a while back after a frost but a few whacks with the hammer freed it up.
Van is a T reg (99)
Heres hoping someone can help. Thanks.
toxo is offline   Reply With Quote
Old 04-17-2013, 07:59 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 178
If you have regular rear brakes you may want to check and see if the auto adjusters are working, there is a chance they stopped working and the brakes are having to go further out before they make contact.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 04-17-2013, 08:38 AM   #3
Lord of Slums
Rewards Points: 1,974
No need to check the auto adjusters, they are not working. You can try going in reverse and putting the brakes on to reset the brakes. I would tear into those rear shoes asap.
mj12 is offline   Reply With Quote
The Following User Says Thank You to mj12 For This Useful Post:
BigJim (04-17-2013)
Old 04-17-2013, 10:50 AM   #4
Thanks guys but the LT35s and Sprinters have discs all round for the main brakes. They do also have shoes on the back but only for the handbrake.
Am taking a chance that it's the master cylinder and am going to pick one up shortly. If not I'm gonna be 50 plus out of pocket but I don't have a choice. I don't have a second vehicle so can't just tear it down and then go look for parts and as usual I need the thing working now.
Old 04-17-2013, 12:14 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 178
In that case I would say you are right, that is all there is left, probably trash or the residual check valve is going south.
Jim
Old 04-17-2013, 08:59 PM   #6
ukrkoz's Avatar
Rewards Points: 934
Your take is very likely to be correct. You almost guaranteed to have dual chamber master, with one chamber leaking through, causing piston to go down, and then 2nd chamber picking up and giving you pressure.
But MS-s are normally easy rebuilt. You can buy rebuilt kits for almost any. 30 minute son a bench and there you go.
ukrkoz is offline   Reply With Quote
Old 04-18-2013, 05:29 AM   #7
This would make sense because the problem got worse each time I used the van and the pedal got lower each time before the brakes were activated as if a leak was gradually getting worse.
Old 04-18-2013, 06:05 AM   #8
r0ckstarr's Avatar
Rewards Points: 1,988
Have you checked for leaks?
Have you verified that there is fluid in the Master Cylinder?
If there is a leak, did you let the MC run empty, then fill it back up again?
If no leaks, then most likely MC is bad.
It would also be wise to visually inspect each brake pad / shoe.
r0ckstarr is online now   Reply With Quote
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Trailer/truck brake controller problem govman Automotive Repairs 6 10-30-2010 03:46 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
