-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   VW GTI belt mystery (http://www.diychatroom.com/f46/vw-gti-belt-mystery-170400/)
noquacks 01-28-2013 05:41 PM
VW GTI belt mystery
Guys,
Trying to help my kid's friend- her 2003 VW GTI 1.8L "T" (turbo??) .
Chilton's import manual is not very clear. It talks of a belt, but none at all in their photos. Then, a page over, it shows a diagram showing a CHAIN at the far end of the straight 4 engine. What is that? The sprocket that would appear to house a belt is on the front side, and far end, a chain. Why would a chain be at the end wjhere the MT is?
Do I have a belt, or chain? If belt, whats that chain?
Thanks!
joecaption 01-28-2013 05:49 PM
Just a guess but most offten I've seen a chain from the crank to the crank shaft so it will not slip and through the motor out of time and bend the valve stems.
The belt would run A/C pump. oil pump, water pump, power steering, may even be the fuel pump.
noquacks 01-28-2013 07:10 PM
Thaks, Joe, but yes, I understand about the serpentine belt/accessory belt- but Im taliking about the timing belt. Thats what Im scared of breakling. So, why would the picture in Chilton's show the chain on the OPPOSITE side of the cam sprocket? Get it? Confusion.
Stories about that belt breaking, and valves crashing into the piston. Too risky to drive the car now.....
Mort 01-29-2013 12:47 PM
Do that belt right away, I just broke one on my wife's Hyundai, and now we'll be doing an engine rebuild with our tax return. Yay me.
As far as the chain, it could be for the balance shaft, but I'm not real familiar with that particular engine.
paintdrying 01-29-2013 04:52 PM
Best to change that belt right away. Look into the water pump and tensioner as well. May not be a bad idea to use vw parts as well. I would try and find a factory manual off ebay. Would not even bother with one of those childrens manuals
joecaption 01-29-2013 06:08 PM
That belt that you need to change should be right there in plan sight.
Some place there going to be an idler pully that you use a socket on to releve the tension on the belt.
Any car of truck I've ever got stuck working on also had a diagram some place show how it's ran, some are on the hood, shroud over the fan blade Ect.
paintdrying 01-29-2013 09:36 PM
Let us just start from the top. What is the car doing, which exact belt are you talking about? Year make and model...
johnniebravo 01-30-2013 04:06 PM
Without knowing what your problem is its difficult to assist with a diagnosis. If you are simply over your mileage limit for the timing belt, have a look here:
http://forums.vwvortex.com/showthrea...iming-Belt-DIY!
It will take a little patience to get through some of the fluff, but VW Vortex is PACKED with info.
noquacks 01-30-2013 06:35 PM
Too Much! Thaks, johny, for the link! Only hope is- thats a 2002, mine is a 2003. I have a feeling that 2--2-2--3 jump was a change for a generation, but not 100% sure.
noquacks 01-30-2013 06:37 PM
Sheesh, I shoulda explained more- the car has 135,000 on it and NEVER had a timing belt changed!!!!! Now, see what I mean?! Yup- I told her NOT to drive that car anywhere!!! WALK!
noquacks 01-30-2013 06:39 PM
But, when I looked up the diagram in Chiltons, it showed a chain at the other end. never seen this before. And, the chioltons didnt even have a section on timing belt! Not even in the index! Paint suggested a manual from ebay. Time to check it out.....
Mort 01-31-2013 10:03 AM
I was thinking that chain might have something to do with the variable valve timing. Either way, you wouldn't have to do anything with it, only a belt (if in fact it exists).
noquacks 02-01-2013 07:20 PM
Update: stumbled across some info- my car DOES have a tim belt. That chain is the other end, connects exhaust/intake cams with crank, I believe. Either way, belt has to be changed.
paintdrying 02-02-2013 12:56 AM
Probably the hardest part of that job is getting the crank nut loose. It is Not that bad of a job, I personally would not do it. I would tell you that is not a good car to learn on.
grizzzlle 02-02-2013 08:12 AM
Yup. My Passat on almost everything is not a car I would recommend not learning on. Now my Tercel is easy on the other hand.
