Vapor Under The Hood! - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-15-2013, 10:33 AM   #1
Bigplanz's Avatar
Rewards Points: 978
Vapor under the hood!
Mercury Villager, 1995. Yesterday, I left work and at a stoplight white vapor was pouring out from under the hood. I stopped, opened the hood and white vapor billows out. Temp gauge was normal. I turned off the heater, and drove home, watching temp gauge. It stayed normal. After I had gone about 4 miles, I pulled over and opened the hood. No vapor. I checked the coolant recovery tank and it was empty. Drove home and today drove the five miles to work with no vapor. Temp gauge did go up to higher in the normal range but the fan kicked on and the temp went down. No overheating has occurred.
Today I put some antifreeze (a quart, maybe) in the recovery tank, and the vapor returned. Turned off the heater and the vapor went away. Temp gauge goes up a little but fan brings it back down.
This is puzzling. I'm going to replace the radiator cap because it's cheap but I doubt that is the issue. No coolant leak detected. No coolant on the ground, no hissing from the engine compartment.
Any ideas on what may be causing this? Thanks.
Bigplanz is online now   Reply With Quote
Old 02-15-2013, 11:04 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,060
Ayuh,... Sounds like ya got a Leak, in the heater circuit...
Bondo is online now   Reply With Quote
Old 02-15-2013, 11:32 AM   #3
Bigplanz's Avatar
Rewards Points: 978
That occurs to me as well. No puddles or evidence of wetness anywhere, and no smells of antifreeze. I will trouble shoot this weekend to find where the vapor is coming from. Seems to be sourced back on the firewall.
Old 02-16-2013, 05:35 PM   #4
ukrkoz's Avatar
Rewards Points: 946
Hey, Bondo, what's with all the Ayuh-s? Is this some sort of a clan call?
Anyhow. So you fill the expansion canister and vapor shows, and if it's low in expansion canister, no vapor? How about crack IN THAT CANISTER throwing some coolant, not much, onto something hot? Pinhole leaks are very hard to spot. Maybe do a dye test?
ukrkoz is offline   Reply With Quote
Old 02-16-2013, 06:34 PM   #5
Rewards Points: 13,458
Take it to any garage and have them do a simple pressure test. If it's going to leak it will leak at a much higher pressure.
Old 02-17-2013, 11:17 AM   #6
Bigplanz's Avatar
Rewards Points: 978
I replaced the radiator cap, filled the recovery tank to "max" and drove it around town. No vapor, no fluctuation in temp on the gauge. Hmmmmm.
Old 02-17-2013, 10:02 PM   #7
Stant radiator cap? Stant is the best! You may have gotten a new crappy cap that will not hold pressure. Ylaps will rent a pressure tester for the radiator, get the dye and light and glasses kit and look for leaks. Should be easy to find that leak if it is making vapor. Cap may have been the problem....
paintdrying is offline   Reply With Quote
Old 02-18-2013, 06:16 AM   #8
Bigplanz's Avatar
Rewards Points: 978
Got it at autozone. Cheap generic. The van still had the original cap which was pretty crudy. So far, so good.
Old 02-18-2013, 07:37 AM   #9
Their is a chance that that generic cap is not holding the proper pressure. With a lower pressure that leak will not show itself.
Old 02-19-2013, 12:03 PM   #10
Bigplanz's Avatar
Rewards Points: 978
Drove the van this weekend all around town, plus 20 miles on the interstate. No vapor, temp gauge normal, no fluctuation at all.
Drove to work Monday, no issues. Left work, vapor at the first stoplight. Vapor gone when car fully warms up, heater off. Turn on heater with engine hot, no vapor. No sign of overheating.
This vapor condition occurrs when I leave work. I park on the 6th floor of a parking garage. Can't think of why that would matter, but going down seems correlated with vapor.
Pressurized systems with leaks will leak whenever the system is pressurized, not every now and then. Very odd situation!
Old 02-19-2013, 12:38 PM   #11
take a few days off work- see if condition improves
Old 02-19-2013, 12:56 PM   #12
Bigplanz's Avatar
Rewards Points: 978
Hey! Great idea! Maybe even retire!!
Old 02-26-2013, 04:13 PM   #13
Bigplanz's Avatar
Rewards Points: 978
About six days ago, I took off the radiator cap and filled up the radiator. Put the cap back on and haven't had any vapor since. Heat is strong, no vapor, temp gauge reads normal. Oh well. Not gonna argue with, uh, success.
Old 02-26-2013, 07:03 PM   #14
r0ckstarr's Avatar
Rewards Points: 2,012
Can't beat a cheap fix.
r0ckstarr is online now   Reply With Quote
Old 02-27-2013, 05:14 PM   #15
Rewards Points: 1,062
Glad you got it, finally. Yup, cheap caps, made in Mexico.....If it was indeed anti freeze (looks klike it was) it wasnt vapor, but fumes or smoke. Bigplanz, youve been smokin, not sniffin.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Hard wiring range hood Neilolo Electrical 3 03-04-2012 02:57 PM
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 06:19 AM
suggestions on contructing a range hood steve1234 Carpentry 15 08-30-2010 10:35 PM
Range Hood install opinion Manshri Appliances 5 01-01-2010 12:04 PM
Hood / Vent Requirements for Gas Stove WaldenL HVAC 1 09-09-2009 03:38 PM
