Upper Control Arm Price - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-14-2011, 08:43 AM   #1
Upper control arm price
Got a 98 ford ranger amd was wondering the roundabout price that replacing the upper control arm and ball joint for the drivers front side would be? Thanks yall
JohnDeereGreen is offline   Reply With Quote
Old 01-14-2011, 12:58 PM   #2
ukrkoz's Avatar
Rewards Points: 934
no DIY? it's not that bad... as far as you have control arm out, you can either hammer ball joint out and replace yourself, or take to most tire shops and such, and they will replace it for you.
unless control arm is busted. but the new one should come with ball joint pressed in anyway.
from Ranger experience, ball joints don't have zerks in them. do yourself a favor, install zerks yourself. ball joints, tie rod ends. pack them up with good grease. you'll never have bad joint again.
oh, and should you decide to DIY, replace bushings on BOTH upper and lower arms. it's about same labor to get both out. will snug up suspension greatly.
ukrkoz is offline   Reply With Quote
Old 01-14-2011, 04:17 PM   #3
I was planning on doing it myself...but have never heard of 'zerks' before...what r those
Old 01-14-2011, 09:11 PM   #4
ukrkoz's Avatar
Rewards Points: 934
oh, it's old timers talk.
grease fittings.
you can buy a box of them for few bucks and drill a proper hole in ball joint or such, screw it in, pack with grease, and be happy. i had really badly squeaking driver side ball joint, did this - never heard squeak again
https://secure.wikimedia.org/wikiped...Grease_fitting
Old 01-14-2011, 09:49 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a very quick perusal of the internet shows a ball joint is somewhere around $20-$30 (there are a couple different part numbers possible). They are pressed in. Autozone loans a ball joint compressor you can use to remove and re-install the new balljoint. I think Advance Auto parts does as well.
Is there a reason you were asking for the entire control arm? Is is damaged? Bushings in decent shape?
Water heater control valve only works if I bang it papashaq Plumbing 1 01-07-2011 03:32 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Air Source Heat Pump Lock-Out Control sydneysm HVAC 7 11-11-2010 05:58 PM
Dishwasher Control Panel Zen Nomad Appliances 0 10-02-2010 12:00 PM
tapping into well control box? jjkrem Electrical 6 02-01-2009 12:03 PM
