Unsuccessfully Changed Spark Plugs - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-25-2013, 07:59 PM   #1
sweaty
Rewards Points: 276
I have a 2004 Ford Taurus Wagon with DOHC engine. I just changed all 6 plugs, put in new coils in the back, and replaced the 6 gaskets under the intake manifold.
After reassembling everything, I started it up. It idled smoothly for a minute and then it made unusual sounds, then sounded like a cylinder was cutting out.
What do I do now?
sweaty is offline   Reply With Quote
Old 07-25-2013, 09:49 PM   #2
ukrkoz's Avatar
Rewards Points: 990
Check all connections? Something's loose...
ukrkoz is online now   Reply With Quote
Old 07-25-2013, 09:57 PM   #3
Still Decompressing
Rewards Points: 273
is this a coil-on-plug motor?
Why do you suspect the plug change is your problem? The pugs, themselves are pretty hard to screw up.
caveeagle is offline   Reply With Quote
Old 07-25-2013, 10:19 PM   #4
Rewards Points: 254
It's possible something went down the intake when you had the plenum off. Figure out what cyl is missing and do a compression test.
cjm94 is offline   Reply With Quote
Old 07-26-2013, 04:39 AM   #5
sweaty
Rewards Points: 276
It is a coil-on-plug motor. I was careful to connect everything back. I did notice that a little plastic clip that secures a connection to one of the back coils broke off. It was very brittle. I taped it with electrical tape.
Is it also possible that a coil is not secured to a plug? I guess anything is possible. I'm trying to fix this myself as a garage want hundreds of $ to take off the intake manifold to get at the back plugs.
Old 07-26-2013, 05:43 AM   #6
sweaty
Rewards Points: 276
I started it up this morning. It sounded like all 6 cylinders were running. It idled faster, then slower, faster, slower, died out.
Old 07-26-2013, 06:53 AM   #7
Rewards Points: 254
May have knocked off a vacuum hose. Listen for a loud sucking noise when it's running
Old 07-26-2013, 09:08 AM   #8
Still Decompressing
Rewards Points: 273
If you suspect a vacum leak (I would), you can also spray some carb cleaner around. A vacum leak should suck up the carb spray (engine running) and should level off the rpm enough to make the leak obvious.
Old 07-26-2013, 09:13 AM   #9
Rewards Points: 112
Does this car have an IAC valve?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is online now   Reply With Quote
Old 07-26-2013, 12:57 PM   #10
sweaty
Rewards Points: 276
I took off the intake manifold again to make sure everything is tight. I also used the correct bolt tightening sequence. After spraying card cleaner, I think there a vacuum leak at the EGR valve. But I don't know how to fix it.
Old 07-26-2013, 01:27 PM   #11
Still Decompressing
Rewards Points: 273
can you post a pic of your EGR valve?
Some have a gasket at the base where they bolt on.
Sometimes the EGR valve get clogged up with carbon build-up. You can clean them off with brake cleaner that sometimes helps.
If you truly have a vac leak, you need to resolve that first.
Old 07-27-2013, 05:39 PM   #12
ukrkoz's Avatar
Rewards Points: 990
1. you DID have a poor connection on one of the ignition coils. One that you taped.
2. If you replaced all six intake gaskets, chances are, you have air leak at one of them.
- old gasket material may have not been completely removed, causing air leak
- gasket was damaged during installation
- sealant was not applied
- an air line was broken or loosened
Are you using straw to shoot solvent at the engine, or wide spray? Use straw, as wide spray gives wide area of possible air leak
- it's a job that requires at least several sensors to be disconnected. Are they all connected back and tight?
Old 03-29-2014, 03:57 PM   #13
Probably stating the obvious but did you verify all of your wires are going back to the correct plug, look up firing sequence if needed and double check. Sometimes it's the easiest things
Jdwilson112 is offline   Reply With Quote
Old 03-29-2014, 04:47 PM   #14
ukrkoz's Avatar
Rewards Points: 990
There is no wires going to plugs. He has ignition coils.
Old 04-01-2014, 11:30 AM   #15
r0ckstarr's Avatar
Rewards Points: 2,064
By any chance, is this misfire causing a check engine light to come on?
r0ckstarr is offline   Reply With Quote
Spark plugs seizing on high mileage engines:myth or fact? toolaholic Automotive Repairs 18 11-13-2012 11:39 AM
Inspecting spark plugs in a high mileage car Bigplanz Automotive Repairs 16 07-18-2011 06:28 AM
'06 Impala - how to change spark plugs + gap spec. DIYguy2000 Automotive Repairs 0 06-20-2011 09:26 AM
Changed spark igniter. Get pilot but gas never comes on... verycold HVAC 25 01-22-2011 03:55 PM
Spark Plugs rusty baker Automotive Repairs 13 08-30-2009 08:09 PM
