Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-27-2012, 04:49 PM   #1
Bigplanz's Avatar
Unladen condition, with tires on the ground?
Back shocks on my 95 Villager will need to be replaced, probably in the spring since I don't have an indoor work space. It is pretty straight forward but the installation requires the vehicle to be in an unladen condition with tires on the ground. I know what an unladen condition is but do they mean the whole weight of the vehicle should be on the ground or just the tires barely touching the ground? I am guessing the whole weight of the vehicle should be on the tires but thought I'd check. Thanks.
Bigplanz is offline   Reply With Quote
Old 11-27-2012, 06:59 PM   #2
Master General ReEngineer
Bondo's Avatar
Naw,... That means the full weight of the vehicle is on jackstands, holding the Body up, 'n the tires, still Just touchin' the ground...
Yer tryin' to unload the suspension...
Old 11-27-2012, 08:38 PM   #3
Bigplanz's Avatar
Thanks!
Old 11-27-2012, 09:10 PM   #4
are the shocks inside the springs or outside?
redman88 is offline   Reply With Quote
Old 11-27-2012, 09:52 PM   #5
ukrkoz's Avatar
btw, as interim measure, drop about 200 lb ballast inside the cargo bay. Spare well always works best. You'll be surprised, how much it'll smooth your ride.
ukrkoz is offline   Reply With Quote
Old 11-28-2012, 06:34 AM   #6
Bigplanz's Avatar
No coil springs on this van in the rear. Leaf springs.
Electric Trailer Brakes and Tires Condition Questions DIYguy2000 Automotive Repairs 10 09-18-2012 09:15 AM
Fried electronics after earth ground accidentally disconnected oukachiru Electrical 7 07-12-2011 04:05 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
