Truck Window Repair - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-02-2011, 11:38 AM   #1
Truck window repair
I own a 2002 Chevy Silverado. The driver's window does not work. I have it apart and found that a cable end came loose. I'm looking for a diagram on how the cable is mounted. Thanks.
waltman is offline   Reply With Quote
Old 07-03-2011, 08:16 AM   #2
ukrkoz's Avatar
Rewards Points: 946
i have 2000 Silverado and you will be better off replacing entire regulator. I had both replaced roughly at 60K miles.
there's really nothing to it.
1/ go to library copy page from Haynes or Chilton
2. go online Autozone/repair manuals
3. buy manual, as you will need it anyway, have my word on it. only about 15 bucks.
regulator is attached to door frame with 4 bolts, covered by plastic. glass is connected to regulator with 2 bolts, you need to lower glass to expose them. there will be 2 openings in frame that will allow you to access those bolts. you will need one of those flexible grabbers, with little prongs coming out when you press the button, as you WILL lose drop at least one of nuts.
i used to tape glass to the outside door panel using masking tape, so that it does not fall down when you remove regulator.
you disconnect regulator, pop it off the frame, fold it it together, and wiggle out through frame opening. last time i did one, took me only about 10 minutes.
aftermarket regulators are around $60 each online, and work very well.
ukrkoz is offline   Reply With Quote
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 08:52 AM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Single Hung Window Removal for Drywall bparise Drywall & Plaster 2 12-12-2009 07:44 AM
Bathroom window issues? Mantaray14 Remodeling 11 12-04-2009 07:40 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
