Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-02-2013, 09:28 AM   #1
Truck chevy
I have a truck I have been rebuild and was curious on any info I can get as far as theses huge tires on this engine it has a v-6 4.3 vortec with 35's on it.. Is this too much tire for the truck??? Thoughts???? Lifted also....
bostonwindows30 is offline   Reply With Quote
Old 02-02-2013, 10:56 AM   #2
World's Tallest Midget
Mort's Avatar
Truck chevy
First of all, it's "Vortec," and it's very possible to run 35s with the 4.3. My only recommendation would be to regear to 4.56s in both axles, otherwise your transmission won't last long. You may also think about 4.88s. Your highway driveability will suffer a bit, but turning those big tires with that small engine will be difficult. You need all the help you can get in acceleration.
Mort is online now   Reply With Quote
Old 02-02-2013, 11:08 AM   #3
Truck chevy
What if I put smaller tires????
Old 02-02-2013, 06:27 PM   #4
Mort's Avatar
Truck chevy
A set of 285/75R16 would be about as big as you should go without regearing. It's about a 33.
Old 02-02-2013, 06:28 PM   #5
Truck chevy
So putting on 33 should be good??
Old 02-07-2013, 10:08 AM   #6
Truck chevy
Note there are other things to consider besides if the engine can handle non-factory specification tires...
That is braking, cornering, and some vehicle electronic modules which measure the rotation speed of the wheels as an input for; shifting, cruise control, speed, leveling, navigation, and even the sound level of the radio.
The newer the vehicle and the more "whistles and bells" the vehicle has, the more things there are which rely on an accurate speed as measured at each wheel. And when you change the wheel/tire size, that also changes the speed those electronic modules "see".
But most important is safety. The factory engineers test the heck out of a vehicle with the factory specification wheel/tire sizes. The vehicle is then fairly safe to drive in most driving conditions. Change the wheel size and height of the vehicle, then roll overs and other nasty things can happen. A lady in such a truck was killed in an accident recently. The braking did not work as it should and she swerved to avoid hitting the vehicle in front of her, and then rolled over.
ABS braking systems rely on accurate wheel speed information.
With that said, the manufacturer and their dealers will have NOTHING to do with modified vehicle like this (because they know it is not safe). I recommend factory specification wheel and tire sizes.
Might want to read the following...
http://www.aamva.org/uploadedFiles/M...s_Findings.pdf
Billy_Bob is offline   Reply With Quote
Old 02-07-2013, 12:30 PM   #7
Mort's Avatar
Truck chevy
Basically, what that link says, is a truck with 39.5"s will handle worse than one with stock 28" tall tires. I've been around the automotive aftermarket for about 16 years as both a professional and an enthusiast, and that's the first I've heard of that.
Actually, no, that's pretty well known throughout the industry.
As far as putting 33s on your truck, I'd be willing to bet there's probably more Chevys of your vintage with that size tire on it than with stock tires. Obviously, don't drive it like a sports car, but if you have any common sense, you'll be fine. If you don't, than sooner or later Darwin will take care of you anyway.
Old 02-07-2013, 01:16 PM   #8
Truck chevy
Thank you for the information, I am going to put 33 on it next weekend.. Should I go smaller?? Might look bad if I put smaller with a lift
Old 02-07-2013, 07:53 PM   #9
Mort's Avatar
Truck chevy
What size wheel do you have?
Old 02-07-2013, 07:57 PM   #10
Truck chevy
They are 16
Old 02-07-2013, 07:59 PM   #11
Truck chevy
I think 33 should be fine, what you think?
Old 02-07-2013, 08:15 PM   #12
Mort's Avatar
Truck chevy
Get 285/75R16, which measures out to be about 33" tall. That'll be just fine. If you go into a tire store and ask for a 33, they'll look at you funny, because barely anybody uses the old style sizes anymore.
Old 02-07-2013, 08:19 PM   #13
Truck chevy
Cool thank you for your help, awesome thanks...
Old 02-07-2013, 09:59 PM   #14
Truck chevy
what gas mileage do you get with that thing ? like 7-8 mpg ?
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 02-09-2013, 10:54 AM   #15
Truck chevy
Made a mistake, they are 17s is this too much? Do I need to change rims also???
Electric Hand Truck for Built in Refrigerator benjamincall Appliances 0 06-15-2012 03:32 PM
Truck ants Thurman Pest Control 17 08-29-2010 08:50 AM
Can a concrete truck get into my back yard? J S Machine General Discussion 55 05-22-2010 01:11 PM
94 chevy 4x4 truck problem tecate1987 Automotive Repairs 45 11-15-2009 01:24 PM
50amp GFI Trips on Commercial Truck djeffwhite Electrical 1 03-10-2008 02:04 AM
