Truck Bedliner On Body Panels? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-22-2013, 07:37 PM   #1
Rewards Points: 512
truck bedliner on body panels?
i have a 2000 gmc sonoma. along my rocker panels and around my fenders the paint is peeling off and there is now surface rust. i want to fix this but i dont want to dump a pile of money into it by going to a body shop.
i drive 8km of gravel road everyday and it really takes a beating. there is already rock guard on the bottom 4 inches and its all peeling. so i was thinking of rolling on some bedliner.
My wife thinks its going to look terrible and i think it'll look fine and possibly more durable then rock guard?
i've never really done any real body work on a vehicle before, i think i got a grasp on this. i was thinking of taking a wire wheel on my grinder and grind all the loose paint paint off and grind the surface rust off. spray rust inhibitor. then get a rust primer and spray it with that. then mask off and roll on the bed liner.
what does everyone think of that? stupid idea? anyone have any better ideas? and anything else that could be helpful would be great.
princelake is offline   Reply With Quote
Old 08-22-2013, 08:50 PM   #2
ukrkoz's Avatar
Rewards Points: 952
Idea is like any other. Some will like some will not. I had a car that had rubber type liner all the way up to the mid door level, but it was painted over with same paint as the rest of the car and looked ok.
I have also noticed, that mate vinyl wraps become more and more popular, so you may get away with it. Just make sure what ever you roll on is not shiny. And do not use paint brush. I'd say, spray it on. For what it will be used, it will look like crap in 2 weeks anyway.
ukrkoz is offline   Reply With Quote
Old 08-23-2013, 05:25 AM   #3
raylo32's Avatar
Rewards Points: 1,280
Over in my Toyota Tacoma forum a lot of guys use plasti-dip for, well, just about anything, including fender flares and probably even fenders. It had become sort of a fad and I think it has progressed so far a couple guys might even have plasti-dipped their wives. ;-)
http://www.tacomaworld.com/forum/sea...archid=9874719
Live long and prosper.
raylo32 is online now   Reply With Quote
Old 08-23-2013, 07:08 AM   #4
Rewards Points: 36
I'd also recommend mud flaps for all four wheels if you don't have them already. They keep a lot of gravel from even hitting the truck.
daveb1 is offline   Reply With Quote
Old 08-23-2013, 10:10 AM   #5
Rewards Points: 154
Go to some truck sites and do a search. Many, many people have coated parts of their truck's body with Linex or Rhino. A few people out there have actually done entire trucks. If you care about it fading you should put stuff on it with additives to prevent that.
eharri3 is offline   Reply With Quote
Old 09-01-2013, 09:02 AM   #6
Household Handyman
Rewards Points: 1,408
Here in S.Ga. it's not unusual to see pick-ups, jeep-like vehicles, and 3/4 ton farm type trucks with some type of bed liner material on the body panels, especially on the rocker panel area. One body shop here uses a spray on material that can be colored to closely match the original body color. I recently saw a yellow Dodge Ram in a big box store parking lot and had to look twice to realize that the entire truck had been sprayed with yellow "bed-liner" type material. Darn thing actually looked good.
Old 09-03-2013, 02:38 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,558
Plasti-Dip is going to be much cheaper.
Old 11-20-2013, 11:16 AM   #8
Plasti-DIp is cheap and it has become more popular. But, I still like Bed Liner on EVERYTHING. It's cheap tooo once prep is out of the way and it looks awesome and protects really well too. It's repairable and a permanent solution. Not saying plasti-dip is bad, just my preference is bed liner.
I have used raptor in the past for this stuff. I tried spray-lining recently and I like it. It took a little while to get the instructions right, but it's superior in thickness and behavior once cured fullly. Check it out at http://www.spray-lining.com/buy-spray-coatings
I am pretty sure you will be stoked with the outcome......
Here is a removable hard top from a Jeep we just did.
Kacee is offline   Reply With Quote
Old 11-20-2013, 11:23 PM   #9
firehawkmph's Avatar
Rewards Points: 1,884
My son and his buddies have sprayed entire cars with the truck bed liner that comes in aerosol cans. They lightly scuff down the car, wipe with prepsol. Then let her rip. Seems to hold up well and doesn't look bad.
Mike Hawkins:yes
firehawkmph is offline   Reply With Quote
Old 01-05-2014, 09:54 AM   #10
RustPicker's Avatar
Rewards Points: 14
I can tell you all the U.S. Navy submarines here on the right coast... (Ok... That's not accurate...) all the U.S. navy Fast attack submarines out of Norfolk, Va use Line-X on deck where crew is required to walk/work.
That stuff is just about bullet proof, provided whatever it's going on is prepped correctly. I have friends who've
Finished their V-Twin Cruiser Motorcycle with the bed liner finishes. When asked why, they're response was,
"With paint and Chrome, everyone gets bent outta shape when it's dirty, tarnished or oxidizing.... With bed liner, when it's wet and/or dirty.... Who cares?"
Sounds K.I.S.S. To me....
Regards,
RustPicker - Sent from my iPad using DIY Forum
RustPicker is offline   Reply With Quote
Old 01-15-2014, 04:26 PM   #11
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
I love plastidip, but for a durable solution I think you're going to want the bed-liner instead of the rubberized dip spray.
The thing is, with the rust already started, putting liner over it is just going to make your surface rust continue under the panel. You would probably be served best by treating/removing the rust before you apply anything over it. A little bonding primer over the treated areas should make sure there is no adverse reaction between the liner and bare metal (I'm not sure how that liner may affect bare metal).
FWIY, my fully plastidipped toy (Anthracite Gray Metallic plastidip):
hyunelan2 is offline   Reply With Quote
Old 02-05-2014, 09:30 PM   #12
halfbreednerd's Avatar
X2!! I too LOVE plastidip, but as stated wouldn't fix the problem. Only cover it up. I think the OP was heading in the right direction with prepping, treating, priming the area. Not sure I would use a wire wheel though :-/ maybe just some sand paper to scuff up the paint and smooth out any rust bubbles. Since you aren't cutting any of the rust out you shouldn't have too much into it at all.
I vote yes for the bed liner! I've seen several cars/trucks with it and I am considering doing my Fury in it. I like the rugged look over the chrome and bring of most vehicles.
I plastidipped my wheels, fairing and nerf bars. It's held up well but I will be peeling it off to bed line it all this spring.
halfbreednerd is offline   Reply With Quote
Electric Hand Truck for Built in Refrigerator benjamincall Appliances 0 06-15-2012 02:32 PM
3 phase panels and sub panels michael825 Electrical 32 08-31-2011 08:43 AM
Truck ants Thurman Pest Control 17 08-29-2010 07:50 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
