Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-08-2013, 10:22 AM   #16
Bigplanz's Avatar
Transmission stop leak?
I had the van on a pair of 8000 pound rated ramps, wheels chocked on. Both sides, parking brake on. I also have a pair of three ton and six Tom jack stands for use if needed. I never get under a car without proper support.
Bigplanz is offline   Reply With Quote
Old 01-08-2013, 01:03 PM   #17
r0ckstarr's Avatar
I've read horror stories on car forums, and always feel the need to mention jack stands everytime someone works on a car. Good to know you have it covered.
r0ckstarr is offline   Reply With Quote
Old 01-08-2013, 02:05 PM   #18
Bigplanz's Avatar
I had a car fall off a jack once. I was standing beside it; no injuries, but not something you forget. I had to replace a starter in a downtown parking garage and it took two trips on the bus to get the jack stands and blocks to the car.
Old 01-08-2013, 10:20 PM   #19
r0ckstarr's Avatar
When I was younger, I jacked up my truck to look at the rear brakes. My intentions were to pull the drum off and decide if I need new shoes, then put the drum and wheel back on. I figured that this wouldn't take long, so why bother getting jack stands, right?
Wrong.
As soon as I slid the wheel off of the lugs, the jack started failing. A seal gave out and the truck slowly started dropping. My father started pumping the jack to try to keep it up, but with every pump, it would fall a little faster. So, he was pumping away as fast as possible while I was trying to get one lug nut started to hold the wheel on.
That was enough to scare me.
Sorry about straying off topic.
Old 01-09-2013, 06:58 AM   #20
Master General ReEngineer
Bondo's Avatar
I cleaned up everything I could reach and ran it a few days. The leak is from the oil seal where the passenger side half axle goes into the tranny. A lot to take apart to replace a five dollar seal.
Ayuh,... But it's a 'ell of alot Less work than pullin' the tranny to change the T/C Seal.....
Poppin' the axle out is fairly Easy, once the ball-joint is split...
Old 01-09-2013, 06:04 PM   #21
Bigplanz's Avatar
Axle is not too hard but the axle nut is a drag to get off.
Apartment water leak - questions haris General Discussion 2 03-23-2011 08:26 PM
Seal for a leaking hot water heater safety valve topspinken General Discussion 9 10-14-2009 04:51 PM
Strange Winter Roof Leak Dragon Roofing 16 10-09-2009 07:06 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 07:30 AM
