Transmission In 96 Plymouth Voyager 3.3L - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-25-2011, 09:39 AM   #1
Transmission in 96 plymouth voyager 3.3L
....Input hub shaft has no play after putting the transmission back together.... everything seems to fit right on the side and is all in order....it spins the gears when using plyers.... would it work?
xohoneyox22 is offline   Reply With Quote
Old 06-25-2011, 10:23 AM   #2
Rewards Points: 252
I assume this is a manual transmission? That's pretty rare on a minivan so I thought I should ask.
If the internal bearings were in good shape, the shafts weren't chipped or worn down and the gears/syncros are good, then I would think you should be fine.
Marty1Mc is offline   Reply With Quote
Old 06-25-2011, 10:26 AM   #3
its an automatic... it had play in the shaft before it was taken apart
Old 06-25-2011, 10:35 AM   #4
Rewards Points: 252
OK, shaft play is indicative of a bad bearing. Many times with the shaft moving around, it gets damaged (the teeth mesh wrong, wear and chip). But, if you have checked all of that, and didn't find a bunch of metal in the pan, it should be ok. I would install it and see what happens.
Without some special gauges, you can't pressure test it anyway.
Old 06-25-2011, 11:29 AM   #5
ok ty this will be the 4th time putting it in so wish us some luck ill let u know if it works
03 Escape Drum Brake Question itguy08 Automotive Repairs 7 07-06-2011 02:30 PM
Transmission question for any experienced mechanics Richo Automotive Repairs 12 05-28-2011 11:17 AM
Mid 90's plymouth voyager alt replacement dirtrider73068 Automotive Repairs 0 10-30-2010 10:02 PM
Transmission chevy motor automatic sharlani Automotive Repairs 6 07-23-2009 10:39 PM
97 plymouth grand voyager died jamesw6777 Automotive Repairs 15 10-30-2008 08:41 PM
