I have even tried GripTight on that plug plus cheat bar . No. Rubber seal they have in the plug simply melted and super glued to pan. Even after I had pan off and in vise, I had to drill plug out.
Btw, I biceps curl 175, so ....
Not sure which seal you left in place, pan seal or filter seal. If you left pan seal in place, you will regret it later. It will leak.
Of course, unless you put a good dab of red gasket sealant along perimeter. Even so... Not a good idea.
If you left filter O-ring in place, that's different story.
Smart guys take pan to a welder, drill hole and weld large nut inside, creating drain plug. Late now.
Lucas is STRONG MEDICINE. Good choice. Hope you did not move solenoid connectors in the trannie rear. Those are known to come off from breeze.
