Trailer Lights Acting Funny - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-16-2009, 07:11 PM   #1
Learning by Doing
Leah Frances's Avatar
Trailer lights acting funny
The lights on our small class 1 trailer are acting funny.
Symptoms:
-Left side rear light does not ignite when the car is 'on' (right side ignites - running lights).
- When the brakes are engaged the left side light ignites, but only to the level of the running lights - not 'bright' like the right side.
Ideas for how to troubleshoot this?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-16-2009, 07:30 PM   #2
Concrete & Masonry
Rewards Points: 568
99% odds it's a grounding problem.
jomama45 is offline   Reply With Quote
Old 04-16-2009, 07:37 PM   #3
Learning by Doing
Yeah, figured that one all on my own. I just don't know how to troubleshoot it to find where the fault is. Thoughts?
Old 04-16-2009, 07:48 PM   #4
Concrete & Masonry
Rewards Points: 568
Some trailers are grounded thru the vehicle hitch, so you can try wirebrushing the hitch ball first.
If that doesn't work, check for a loose white wire @ the trailer tongue or at the left rear tailight.
If that doesn't work, check the white wire at each taillight & running light.
If all of that doesn't work, check all the wires to make sure they didn't wear thru, especially at penetrations.
Old 04-16-2009, 08:01 PM   #5
Post a schematic; we'll step you through it.
You can use clip leads and the vehicle battery to check the trailer lights separately from the vehicle.
This lamp or equivalent used?
#1034 MINIATURE BULB BAY15D BASE - 12.8/14.0 Volt 1.80/0.59 Amps S8 Double Contact (DC) Index Bayonet (BAY15d) Base 200/5000 Average Rated Hours 2.00" Maximum Overall Length #1034
A bad ground will cause the thick filament to supply current to the thin filament, but the thick one doesn't light while it's doing this.
Old 04-16-2009, 08:03 PM   #6
Learning by Doing
I'll put something up - just for giggles it appears that they coated all the wires black with some sort of paint.
Old 04-16-2009, 08:29 PM   #7
HVAC / Plumbing
If the bulbs are 1157 type Check the bulbs for corrosion at the terminals.. I replaced the lights on all my trailers with the LED style... Now I have o light problems
kenmac is offline   Reply With Quote
Old 04-17-2009, 02:55 AM   #8
Household Handyman
Rewards Points: 1,408
I've wired many a trailer, tag-a-longs, fifth wheels, boat, utility, cargo, and car hauler trailers. One thing I've learned to do to save me or someone else problems down the line is to use the white grounding wire(s) starting from the tow vehicle all the way to each light set. I just do not use the trailer framing or the hitch ball as the ground. Make a good ground on the tow vehicle if there is not one and carry it through the connector. Ground problems are probably about 95% of trailer light problems. Good Luck, David
Old 04-17-2009, 05:36 AM   #9
Safe, Most of the Time!!
brokenknee's Avatar
Is this problem specific only to this trailer? The first check would be on the tow vehicle. You can purchase a test light that plugs into your trailer light connection for only a few dollars. Most problems I have had with trailer lights either is a ground on the tow vehicle or problems in the connector itself.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 04-17-2009, 08:05 AM   #10
Learning by Doing
Reality check - I'm used to house electrical so 12V DC is a strange new world. There are only two wires that run to each light. One is 'hot', right? The other is the 'ground/neutral'? If I run another 'white neutral' do I use it in lieu of the ground/neutral? In addition?
The wires running into the lights are both the same colored wire.
Old 04-17-2009, 08:27 AM   #11
Concrete & Masonry
Rewards Points: 568
Nothing like residential wiring. If I remember correctly:
White = ground
Brown = tailights/running lights
Yellow = left turn
Green = right turn
So, you should have a brown & yellow going to left tail, & brown & green going to right tail, theoreticaly. I would take a closer look at the left tailight , as it has to be grounded through the frame some how. I'm sure it too rusty/corroded to make a good ground.
Old 04-17-2009, 08:30 AM   #12
Learning by Doing
Connection (ground) is established through the bolt that fastens the light to the trailer. I will check to make sure the connection is good and free of corrosion. FYI, the trailer is less than 1 year old.
Old 04-17-2009, 11:11 AM   #13
Nobody ever died from 12v in the conventional sense so Hot and Neutral kind of lose their meaning, along with the wire colors.
Old 04-17-2009, 11:52 AM   #14
Learning by Doing
Each side light has two wires going to it. White wire seems to terminate at the ball. If I want to run a separate neutral/ground what would I hook it up to at the light end. Each light has two terminals - where would I attach the white?
Old 04-17-2009, 01:13 PM   #15
HVAC / Plumbing
If you have the 4 prong plug .The w from the plug will have to tie into both whites at the lights that wat you are directly grounded to the lights.. Not grounding through the trailer frame
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
kitchen sink hot water acting funny jr2dr Plumbing 5 10-29-2008 07:56 PM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 08:25 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
Sink Sprayer acting funny... zel Plumbing 3 09-06-2007 05:01 PM
