The lights on our small class 1 trailer are acting funny.
Symptoms:
-Left side rear light does not ignite when the car is 'on' (right side ignites - running lights).
- When the brakes are engaged the left side light ignites, but only to the level of the running lights - not 'bright' like the right side.
Post a schematic; we'll step you through it.
You can use clip leads and the vehicle battery to check the trailer lights separately from the vehicle.
This lamp or equivalent used?
#1034 MINIATURE BULB BAY15D BASE - 12.8/14.0 Volt 1.80/0.59 Amps S8 Double Contact (DC) Index Bayonet (BAY15d) Base 200/5000 Average Rated Hours 2.00" Maximum Overall Length #1034
A bad ground will cause the thick filament to supply current to the thin filament, but the thick one doesn't light while it's doing this.
If the bulbs are 1157 type Check the bulbs for corrosion at the terminals.. I replaced the lights on all my trailers with the LED style... Now I have o light problems
I've wired many a trailer, tag-a-longs, fifth wheels, boat, utility, cargo, and car hauler trailers. One thing I've learned to do to save me or someone else problems down the line is to use the white grounding wire(s) starting from the tow vehicle all the way to each light set. I just do not use the trailer framing or the hitch ball as the ground. Make a good ground on the tow vehicle if there is not one and carry it through the connector. Ground problems are probably about 95% of trailer light problems. Good Luck, David
Is this problem specific only to this trailer? The first check would be on the tow vehicle. You can purchase a test light that plugs into your trailer light connection for only a few dollars. Most problems I have had with trailer lights either is a ground on the tow vehicle or problems in the connector itself.
Reality check - I'm used to house electrical so 12V DC is a strange new world. There are only two wires that run to each light. One is 'hot', right? The other is the 'ground/neutral'? If I run another 'white neutral' do I use it in lieu of the ground/neutral? In addition?
The wires running into the lights are both the same colored wire.
Nothing like residential wiring. If I remember correctly:
White = ground
Brown = tailights/running lights
Yellow = left turn
Green = right turn
So, you should have a brown & yellow going to left tail, & brown & green going to right tail, theoreticaly. I would take a closer look at the left tailight , as it has to be grounded through the frame some how. I'm sure it too rusty/corroded to make a good ground.
Connection (ground) is established through the bolt that fastens the light to the trailer. I will check to make sure the connection is good and free of corrosion. FYI, the trailer is less than 1 year old.
Each side light has two wires going to it. White wire seems to terminate at the ball. If I want to run a separate neutral/ground what would I hook it up to at the light end. Each light has two terminals - where would I attach the white?
The ground connection is the lamp housing. I'd put a ring terminal on your new ground wire and put the terminal between the head of the bolt and the housing.
Added: Automotive (trailer) wiring is suspect to corrosion. Get the shrink style ring terminals.
If you have the 4 prong plug .The w from the plug will have to tie into both whites at the lights that wat you are directly grounded to the lights.. Not grounding through the trailer frame
Cool. I've got a spare spool of brown bell wire I can use to do the neutral/ground.
Just kidding. :laughing: White wire it is!
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
