Trailer Brakes - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-14-2009, 12:44 PM   #1
Question
trailer brakes
I have a 2002 GMC Sierra, I bouhgt this truck used, it has the tow/haul button on the end of the shifter and the hitch in the rear already set up. I was wondering how can I tell if it is equipped with the trailer brake control box?
Charlie
Chas720 is offline   Reply With Quote
Old 07-14-2009, 06:23 PM   #2
Typically it would be mounted below the dash on the drivers side. I have a Tahoe with the trailer pacage
but it did not come with the trailer brake controller.
merle is offline   Reply With Quote
Old 07-15-2009, 08:07 AM   #3
Household Handyman
Rewards Points: 1,408
Your 2002 Sierra does not come with the trailer brake controller (control box). In adding a trailer brake controller to your truck it will be necessary to follow the wiring instructions that will come with the particular controller you purchase. IF you have the seven-way trailer connection on your truck, and IF I remember these correctly, you may have the wiring to connect the trailer brake controller up under the dash to the left of the brake pedal. IF SO, they will bundled up and taped up. On the 2002 you may have to run a new "HOT" wire from the fuse box under hood to the new controller. There should be an empty slot for a "brake controller" fuse (30amp) in this box and a stud to mount the the new "HOT" wire to.
Good Luck, David
New Trailer service hd82 Electrical 10 04-23-2009 12:26 PM
Trailer brake problem jcouch4 Automotive Repairs 11 04-23-2009 10:20 AM
Calling All Towing/RV Experts Woofies General DIY Discussions 5 05-15-2008 06:47 PM
Trailer brakes bucksone Automotive Repairs 1 09-01-2007 07:47 PM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 06:31 AM
