-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   trailer brakes (http://www.diychatroom.com/f46/trailer-brakes-48861/)
Chas720 07-14-2009 01:44 PM
trailer brakes
I have a 2002 GMC Sierra, I bouhgt this truck used, it has the tow/haul button on the end of the shifter and the hitch in the rear already set up. I was wondering how can I tell if it is equipped with the trailer brake control box?
Charlie
merle 07-14-2009 07:23 PM
Typically it would be mounted below the dash on the drivers side. I have a Tahoe with the trailer pacage
but it did not come with the trailer brake controller.
Thurman 07-15-2009 09:07 AM
Your 2002 Sierra does not come with the trailer brake controller (control box). In adding a trailer brake controller to your truck it will be necessary to follow the wiring instructions that will come with the particular controller you purchase. IF you have the seven-way trailer connection on your truck, and IF I remember these correctly, you may have the wiring to connect the trailer brake controller up under the dash to the left of the brake pedal. IF SO, they will bundled up and taped up. On the 2002 you may have to run a new "HOT" wire from the fuse box under hood to the new controller. There should be an empty slot for a "brake controller" fuse (30amp) in this box and a stud to mount the the new "HOT" wire to.
Good Luck, David
