Toyota Highlander Maintenance - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-19-2011, 09:00 AM   #1
Toyota Highlander maintenance
I drive about 11k miles per year and I have always went to the dealer for scheduled maintenance. I have come across a maintenance schedule online that could be done at specific intervals which would save money, especially at the dealer. Can anyone tell me if I would be safe in following this maintenance list for my Highlander? Some other Highlander online tell me they have over 100k miles and all they have done is changed their oil over the years, is this something that can be true....honestly now. My Highlander is paid off, bought brand new and to ignore scheduled maintenance is foolish if you ask me. I just don't feel like paying the dealer alot for "checking" things anymore.
5k - Oil Change
5k - Rotate tires
30k - Air Filter
30k - Cabin Filter
When the brake pads need replacing - Brake Fluid
45k - Engine Coolant
dinosaur1 is offline   Reply With Quote
Old 02-19-2011, 09:20 AM   #2
Bigplanz's Avatar
Rewards Points: 990
Personally, that schedule looks fine to me, but it could void your warranty, if you still have one on the car.
Bigplanz is offline   Reply With Quote
Old 02-19-2011, 09:21 AM   #3
6 yrs old
67k miles
This suv is gonna last forever.
Old 02-19-2011, 09:45 AM   #4
Rewards Points: 558
That more or less is a good maintenance schedule and if you follow that you shouldn’t have any problems. You should also check your manual for their recommended scheduled maintenance and tweak it to that if you want. As long as you have records and a regular maintenance schedule of what you have done to your vehicle you will have no problem with your warranty or the dealer unless it stipulates in the warranty that you have to bring your vehicle to them.
epson is offline   Reply With Quote
Old 02-19-2011, 06:51 PM   #5
ukrkoz's Avatar
Rewards Points: 952
he-he
where's saving money in this schedule?
is it 3.0 V6?
my wife has Lexus RX300, which is based on Highlander platform.
I change oil every 12-15000 miles.
Mobil1 or K&N oil filter. Amsoil.
I use only best synth lubricants in transfer case and differential, which you, actually, forgot to even take into consideration, and should be done at 65 000 miles.
stop using paper air filters and switch to K&N air filter. yes, it's 4 times regular one, but lasts forever and improves mpg by about a mile to a gallon.
do your math, what is more cost efficient.
ukrkoz is offline   Reply With Quote
Old 02-19-2011, 08:09 PM   #6
Originally Posted by ukrkoz
he-he
is it 3.0 V6?
Transfer case and differential? They are sealed units so why should they get changed out?
Old 02-19-2011, 08:18 PM   #7
Rewards Points: 79
Only problem is K&N's let in more dirt which may or may not cause an issue down the road especially if you drive in a dusty environment. You also do have to clean and oil them every once in a while too.
Gear oil breaks down over time just like engine oil. There's no blowby and other engine gasses to deal with but there is a lot of heat.
Other than that nothing there seems out of the ordinary - I'd throw in transmission fluid changes ever 30k there if it's an automatic. You may be able to go a little longer on antifreeze - check the owner's manual on that.
itguy08 is offline   Reply With Quote
Old 02-19-2011, 08:26 PM   #8
4 people I know who have driven their Highlanders 200k miles have never changed these.....that's almost laughable.
Old 02-19-2011, 08:31 PM   #9
Rewards Points: 79
200k is NOTHING now a days. Cars are designed for 150k mile service life now so 200k is not the milestone it used to be. That being said it's cheap insurance for the 4x4 system. You can probably get away without it but it's not that much more expensive to go the whole route so it falls under "cheap insurance".
Old 02-19-2011, 08:32 PM   #10
or as dealers like to call it "preventative maintenance"....=)
Old 02-21-2011, 01:55 PM   #11
For someome like me who drives 12k miles per year approx. what is recommended other than what I've already mentioned. Overall I think I'm doing fine and so far my suv is running great.
Help with low maintenance landscaping in Oregon. MindOfVacuity Landscaping & Lawn Care 3 05-18-2014 10:42 AM
IPE Deck Maintenance Question jason206 Building & Construction 2 02-03-2010 04:36 PM
Flat roof maintenance retired guy 60 Roofing/Siding 9 09-26-2009 01:44 PM
hot water heater annual maintenance: a word to the wise diy888 Plumbing 16 03-19-2009 09:59 AM
2004 Toyota 4Runner Maintenance rjordan392 Automotive Repairs 4 03-06-2009 08:02 AM
