Toyota Choking - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-12-2010, 09:22 PM   #1
General Contractor
Toyota choking
My truck will cough momentarily, as I'm driving it feels like I lose power momentarily and it throws me forward, then goes back to normal. I asked a mechanic about it, he said to check where the air enters the engine, the valves could have carbon build up on them.
But I'm trying to figure out where exactly those valves would be, and how to get to them. Can anyone point it out from my picture?
KennMacMoragh is offline   Reply With Quote
Old 05-13-2010, 06:50 AM   #2
47_47's Avatar
Rewards Points: 58
If the valve the mechanic was refering to is your throttle valve, then it is in your lower picture by the plenum. Be careful when removing and do not damage any of the hoses, you have a mass air flow sensor upstream and it will not correctly read the air flow into the engine if you damage a hose.
Sounds to me like an ignition miss. Remove the spark plug wires (one at a time) from both ends and inspect for corrosion. Also check for engine oil in the spark plug wells and possible tracking on the plug insulation.
47_47 is offline   Reply With Quote
Old 05-13-2010, 11:01 AM   #3
Kenn,
Here is a link. Go to the forum section, upper left. Search for your model. These guys and gals are good.
http://www.yotatech.com/index.php
Bill7 is offline   Reply With Quote
Who owns a Toyota ? Scuba_Dave Off Topic 15 02-17-2011 05:59 PM
2004 Toyota 4Runner Maintenance rjordan392 Automotive Repairs 4 03-06-2009 08:02 AM
2000 Toyota Avalon: starting and idling problem proofer Automotive Repairs 3 09-03-2008 09:29 AM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 06:31 AM
