Torx Versus Triple Square? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Like Tree2Likes
Old 11-29-2016, 09:21 AM   #1
Rewards Points: 122
Torx versus triple square?
I will soon be doing a DIY brake pad replacement on a BMW. I watched a DIY youtube video on how to do this job & the presenter on 2 occasions uses Torx bits instead of Triple Square bits. On the first occasion he uses a T30 Torx bit & on the second occasion he uses a T45 Torx bit. On both occasions he mentions that the proper bit to use would be a Triple Square but since he does not have the proper size Triple Square the Torx works just fine. I would really like to use the proper bits if possible but I don't know & can't find the equivalent sizes of bits. Does anyone know what size Triple Square bit would be equivalent to a Torx30 & what size Triple Square would be equivalent to a T45 Torx bit? I know I could buy a whole set of Triple Square bits, but since I would only be using 2 bits & only using them once I would rather just buy the 2 bits I would need. I'm guessing that buying only the 2 bits I need as opposed to a whole set of Triple Squares would save me a few bucks. Thanks
dommm is offline   Reply With Quote
Old 11-29-2016, 09:48 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Re: Torx versus triple square?
Ayuh,.... Ain't seen the 12 point bolts, but,....
A 6 point allen key that fits oughta give ya the size ya need,....
Brainbucket likes this.
The Following User Says Thank You to Bondo For This Useful Post:
dommm (11-29-2016)
Old 11-29-2016, 10:29 AM   #3
Rewards Points: 2,380
For things of this nature, I go to Grainger Supply, they are a major parts supplier of industrial parts, and have access to many tools that are not at the general auto parts house.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
dommm (11-29-2016)
Old 11-29-2016, 10:38 AM   #4
Rewards Points: 122
ED
My issue is not a case of not being able to find a Triple Square bit (they are listed on Amazon) but rather just buying the 2 sizes I would need to do this job. Amazon offers a whole set for sale which includes around 12 bits but it seems a waste of money to buy all 12 in a set if I'm only going to ever need 2 of the 12. I am hoping to find the equivalent sizes for just the 2 mentioned above & then just buy them separately. Thanks
Old 11-29-2016, 10:46 AM   #5
Look the sizes up in a REPAIR MANUAL.
dommm (11-29-2016)
Old 11-29-2016, 10:48 AM   #6
Rewards Points: 122
Good idea but I don't have access to the manual. Thanks for the suggestion though.
Old 11-29-2016, 11:32 AM   #7
Bigplanz's Avatar
Rewards Points: 990
I was removing a window lift motor my my wife's windstar and the stud holding it in was designed for an e socket (female torx) I didn't have one. A 5mm regular metric socket worked though. For the life of me, I don't know why these odd ball sockets and fastener designs are used, randomly, for various parts. If it were me, I would use a Torx since it fits and be done with it.
Bigplanz is offline   Reply With Quote
Old 11-29-2016, 11:52 AM   #8
Brainbucket's Avatar
Rewards Points: 838
Harbor Freight is the place for cheap tools that ya only use once or twice. But as Bondo said you can use an allen or a you can use torx. I have the triple square but before I bought them, I was using allen and/or torx. Some head bolts are triple square so I had to buy them. Remember to replace the pad wear sensor(s) also on BMW's.
If you first donít succeed, get a bigger hammer!
Brainbucket is offline   Reply With Quote
The Following User Says Thank You to Brainbucket For This Useful Post:
dommm (11-29-2016)
Old 11-29-2016, 12:31 PM   #9
Rewards Points: 122
I cut & paste this comment from another DIY site ("Problem with using Torx over triple square. is there is more of a chance of stripping out the head of bolt.") & that is my fear with using any other kind of bit. It appears I will have to bit the bullet & buy a whole set of Triple Squares since no one on this DIY or another DIY that I asked the same question, knows the same/equivalent size from a T30 & T45 Torx to Triple Square. Thanks for your time.
Old 11-29-2016, 12:55 PM   #10
As I said before you can look it up in a real manual.
I'm sure that with the proper research you can find an on-line manual to read.
NOT on you-tube, somewhere else with real useful information.
ED
dommm (11-29-2016)
Old 11-29-2016, 01:21 PM   #11
sestivers's Avatar
Rewards Points: 109
Is there a BMW owner forum in which the members might be able to look in a repair manual for you? Is it possible the library has the repair manual?
Steve
sestivers is online now   Reply With Quote
The Following User Says Thank You to sestivers For This Useful Post:
dommm (11-29-2016)
Old 11-29-2016, 01:30 PM   #12
Rewards Points: 1,668
My NAPA has Triple Square sets for about 58 bucks + tax. I didn't check on individual cross overs to Torx.
I've read on other sites where it is mentioned driving a Torx in to avoid the right tool. Maybe on my 48 ford but not for me on a BMW.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
dommm (11-29-2016)
Old 11-29-2016, 01:38 PM   #13
Rewards Points: 122
ED
Thanks again for your suggestion. Believe me, I have searched high & low for the relevant manual for my situation but have struck out. If I wanted to pony up some cash I could get one but I can't find a free manual. If you have any ideas on where to search on-line or can provide a link to the manual I would forever be indebted to you!
Old 11-29-2016, 02:45 PM   #14
Bondo's Avatar
Ayuh,... I just went out, 'n mic'ed my snap-on torx bits,....
The T-30 is .1865", or just under 3/16",....
The T45 is .2640", which is just under 17/64",....
The Following 2 Users Say Thank You to Bondo For This Useful Post:
de-nagorg (11-29-2016), dommm (11-29-2016)
Old 11-29-2016, 06:51 PM   #15
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
ED
Don't knock YouTube, I just rebuilt an automatic transmission based solely on a series of videos there. There's good stuff if you can weed through the crap.
I hate signatures.
Mort is offline   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
dommm (11-29-2016)
How to best tell what is square and what is not? miamicuse Building & Construction 12 07-14-2012 08:44 PM
1CFM per square foot, or follow heat load calculation? JeepNick HVAC 10 02-08-2012 04:10 PM
Return Air in a 100 square foot closet? JeepNick HVAC 13 02-07-2012 10:21 PM
Getting a 200Amp Square D OQ Panel. What about surge protector? mudworm Electrical 3 10-27-2011 02:29 PM
Ridge vent question dpreznik Roofing/Siding 7 04-13-2007 03:03 PM
