Too Much Oil In 2001 Ford Taurus - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-06-2011, 02:26 PM   #1
Exclamation
Too much oil in 2001 ford taurus
I needed oil so I added 3qts. and drove the freeway to work, 5-6mins into driving white smokke shadowed my car for a mile then went away, came back, n went away, theres also a little flutter in my drive but it goes away once the car gets going. ive been at work for hours, n off @3pm..i checked oil level n its pass the cross hatches, but not pass the word"engine"....is it safe to drive anther 20_25mins. Home?
Shay929 is offline   Reply With Quote
Old 11-06-2011, 07:34 PM   #2
ukrkoz's Avatar
Rewards Points: 940
yes, but make sure your oil filler cap is in place and tight.
ukrkoz is offline   Reply With Quote
Old 11-06-2011, 08:20 PM   #3
Rewards Points: 254
I would change your oil asap. The rough running is most likely oil wrapping around the crankshaft from centrifugal force. Causing the crank to be out of balance. The smoke from extra oil splashing in the rings. Although it isn't great for it if the engine isn't missing or shaking really bad you should be fine. when adding oil if it's in the cross hatches at all you are safe and don't need to add any. Then just one quart at a time and check and you should'nt have a problem over filling again
cjm94 is offline   Reply With Quote
Old 11-06-2011, 08:24 PM   #4
Rewards Points: 254
I have seen a few cars towed into the shop for running very rough...come to find the oil was changed but was never drained so double filled...they all ran ok after draining the oil down to the correct level. Still see one on occasion that was over a year ago running smooth.
Old 11-07-2011, 12:25 PM   #5
ukrkoz's Avatar
Rewards Points: 940
shay, why exactly did you need THREE QUARTS? how did you know? from mark to mark refill on dipstick is normally a quart.
Unique Ford Ranger Exhaust?? Giles Automotive Repairs 3 07-31-2011 03:37 AM
Ford Expidition and F250 Door lock problem danrb007 Automotive Repairs 5 04-05-2011 08:35 PM
1994 Ford Taurus engine cut out/died after short time with knock/rattle when using accelerator 94FordTaurus Automotive Repairs 3 06-02-2010 11:53 AM
2001 ford ranger thermostat repair bshott General DIY Discussions 3 01-16-2010 11:15 AM
1997 Ford Taurus GL Tranny econdave Automotive Repairs 3 11-27-2007 12:17 AM
