Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-19-2013, 09:45 PM   #1
Tires on truck
Had a chevy truck I have rebuilt, everything turned out good it a chevy 1500 95 single can but when I bout it it had 35x12.5xr17 with a 3"lift I like the lift but I think tires are way to big?? And my speed is off I can feel truck straining when driving would it look okay and help truck with 265/70/17?????
bostonwindows30 is offline   Reply With Quote
Old 03-19-2013, 11:52 PM   #2
I'm Your Huckleberry
Tires on truck
not for your truck but the principal is the same. check it out. http://www.youtube.com/watch?v=m3ccAkvP1i0
Thanks.
Doc Holliday is offline   Reply With Quote
Old 03-20-2013, 03:36 AM   #3
Tires on truck
So your saying go with 265 ??? 35 are way too big.. And I think 285 are also too big?????
Old 03-20-2013, 03:39 AM   #4
Tires on truck
This is her
Old 03-21-2013, 03:26 PM   #5
gravity always wins
Tires on truck
Here is a cool tire size calculator. Type in the stock size and then the optional sizes and it will tell you the differences.
http://www.1010tires.com/Tools/Tire-Size-Calculator
Old 03-21-2013, 06:41 PM   #6
Tires on truck
All this tells me is that I can't put them on, the original stock is 225/75/16 I am looking for 265/70/17 it's lifted and would look crazy dumb with 225 on it...
Old 03-21-2013, 07:35 PM   #7
gravity always wins
Tires on truck
So put on whatever you want. The site only tells you what the difference is. Curious as to why you came on here to ask???
Old 03-21-2013, 07:37 PM   #8
Tires on truck
I have on there now 35/12.5/17 there way too much.. Too big!!!
Old 03-21-2013, 07:46 PM   #9
JOATMON
ddawg16's Avatar
Tires on truck
Either go with smaller tires or different gears. For 35's, you should be running around 4.56 gears....4.10 would work but your engine will be on the low side of the sweat spot.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 03-21-2013, 07:48 PM   #10
Tires on truck
What if I go to 265 tire do I still have to re- gear
Old 03-21-2013, 08:03 PM   #11
JOATMON
ddawg16's Avatar
Tires on truck
Sorry....but 265 means nothing to me....I'm old school....I think of tires in terms of diameter....translation...inches as measured from one side to the other.
If you want to know what you 'should' be running....look at the owners manual.
My
and
Old 03-21-2013, 08:07 PM   #12
Tires on truck
They are 31/70/17 the owners manual wants me to put 225/70/16 that would look bad with it lifted???
Old 03-21-2013, 08:30 PM   #13
JOATMON
ddawg16's Avatar
Tires on truck
Well....you have to make a choice....do you want your mall crawler to look cool, or do you want your power back?
If you want the big tires...you have to re-gear.
My
and
Old 03-21-2013, 08:38 PM   #14
Tires on truck
I want the 31" which is smaller u think I need to still re- gear it???
Old 03-22-2013, 06:59 PM   #15
World's Tallest Midget
Mort's Avatar
Tires on truck
265 is the measurement of the section width, so the tire would be 265mm wide. The 75 is the sidewall height, expressed as a percentage. So the sidewall is 75 percent of the section width, or 198.75mm. So, to find out the height, we would take the section width, multiply it by the sidewall height, divide by 50, multiply by 25.4 to convert into inches, and add the rim height, which is 16 inches. So a tire sized 265/75R16 would measure 31.65 inches, approximately.
What could be simpler?
Mort is offline   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
Doc Holliday (03-22-2013)
Electric Hand Truck for Built in Refrigerator benjamincall Appliances 0 06-15-2012 03:32 PM
Truck ants Thurman Pest Control 17 08-29-2010 08:50 AM
Can a concrete truck get into my back yard? J S Machine General Discussion 55 05-22-2010 01:11 PM
Small pneumatic tires not holding pressure Nestor_Kelebay Automotive Repairs 14 04-26-2009 09:39 AM
50amp GFI Trips on Commercial Truck djeffwhite Electrical 1 03-10-2008 02:04 AM
