-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Tires on truck (http://www.diychatroom.com/f46/tires-truck-174981/)
bostonwindows30 03-19-2013 09:45 PM
Tires on truck
Had a chevy truck I have rebuilt, everything turned out good it a chevy 1500 95 single can but when I bout it it had 35x12.5xr17 with a 3"lift I like the lift but I think tires are way to big?? And my speed is off I can feel truck straining when driving would it look okay and help truck with 265/70/17?????
Doc Holliday 03-19-2013 11:52 PM
not for your truck but the principal is the same. check it out. http://www.youtube.com/watch?v=m3ccAkvP1i0
bostonwindows30 03-20-2013 03:36 AM
So your saying go with 265 ??? 35 are way too big.. And I think 285 are also too big?????
bostonwindows30 03-20-2013 03:39 AM
1 Attachment(s)
This is her
Attachment 67658
Maintenance 6 03-21-2013 03:26 PM
Here is a cool tire size calculator. Type in the stock size and then the optional sizes and it will tell you the differences.
http://www.1010tires.com/Tools/Tire-Size-Calculator
bostonwindows30 03-21-2013 06:41 PM
All this tells me is that I can't put them on, the original stock is 225/75/16 I am looking for 265/70/17 it's lifted and would look crazy dumb with 225 on it...
Maintenance 6 03-21-2013 07:35 PM
So put on whatever you want. The site only tells you what the difference is. Curious as to why you came on here to ask???
bostonwindows30 03-21-2013 07:37 PM
I have on there now 35/12.5/17 there way too much.. Too big!!!
ddawg16 03-21-2013 07:46 PM
Either go with smaller tires or different gears. For 35's, you should be running around 4.56 gears....4.10 would work but your engine will be on the low side of the sweat spot.
bostonwindows30 03-21-2013 07:48 PM
What if I go to 265 tire do I still have to re- gear
ddawg16 03-21-2013 08:03 PM
Sorry....but 265 means nothing to me....I'm old school....I think of tires in terms of diameter....translation...inches as measured from one side to the other.
If you want to know what you 'should' be running....look at the owners manual.
bostonwindows30 03-21-2013 08:07 PM
They are 31/70/17 the owners manual wants me to put 225/70/16 that would look bad with it lifted???
ddawg16 03-21-2013 08:30 PM
Well....you have to make a choice....do you want your mall crawler to look cool, or do you want your power back?
If you want the big tires...you have to re-gear.
bostonwindows30 03-21-2013 08:38 PM
I want the 31" which is smaller u think I need to still re- gear it???
Mort 03-22-2013 06:59 PM
265 is the measurement of the section width, so the tire would be 265mm wide. The 75 is the sidewall height, expressed as a percentage. So the sidewall is 75 percent of the section width, or 198.75mm. So, to find out the height, we would take the section width, multiply it by the sidewall height, divide by 50, multiply by 25.4 to convert into inches, and add the rim height, which is 16 inches. So a tire sized 265/75R16 would measure 31.65 inches, approximately.
What could be simpler?
