Tires - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-14-2013, 06:47 PM   #1
Rewards Points: 582
tires
can someone help with a question about tires and wheels....my son has a gmc truck.. tires p265 70r16.....will p265 70r17 tires and wheels work with no problems...thanks ben sr
Old 04-14-2013, 06:54 PM   #2
Rewards Points: 13,446
No, the 16 and 17 is the rims outside measurement.
ben's plumbing (04-14-2013)
Old 04-14-2013, 06:56 PM   #3
http://www.tirerack.com/tires/tirete....jsp?techid=46
Old 04-14-2013, 06:58 PM   #4
Google "tire calculator." Go to the tire calculator that's on a Miata website. You can put in your factory size, then put in the alternate sizes you are thinking of and it will calculate everything for you. Awesome tool, trust me!
jeremy511 is offline   Reply With Quote
The Following User Says Thank You to jeremy511 For This Useful Post:
Old 04-14-2013, 07:20 PM   #5
Rewards Points: 582
thanks jeremy....just what I thougth it would affect speedometer not by much but it still would affect it....ben sr ...yes awsome tool...
Old 04-14-2013, 07:25 PM   #6
Remodeler
Rewards Points: 320
265 is the tire width at the widest point in millimeters, 70 is the ratio of height to tread width, and 16 or 17 is the rim diameter in inches. If you are changing to 17 inch rims and tires it should work fine, since the outside tire measurements would be essentially the same size. Of course you can't put the 17 inch tires on your 16 inch rim.
Going to a larger size rim is not usually a problem, it may be very difficult or impossible to go the other way as the smaller rim may interfere with the brake calipers or drums. For correct fit you need to make sure the rim backspacing is correct when you change wheels. Drastically changing the backspacing may make the vehicle handle differently or cause interference when turning, or leave too much tire outside the fenders.
iamrfixit is offline   Reply With Quote
The Following User Says Thank You to iamrfixit For This Useful Post:
Old 04-15-2013, 08:09 PM   #7
ukrkoz's Avatar
Rewards Points: 946
forget speedo, tires will be rubbing on the tire wells during turns.
ukrkoz is offline   Reply With Quote
Old 04-15-2013, 08:41 PM   #8
There is no way you will rub going from a 16" to a 17" unless you have a serious drop, 3"+ in suspension.
ben's plumbing (04-15-2013)
Old 04-20-2013, 04:44 PM   #9
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
It could, considering the same section width and aspect ratio, the only difference being wheel size, the tire would be 1" taller. That's enough to rub sometimes. What year GMC?
I hate signatures.
Mort is online now   Reply With Quote
Old 04-20-2013, 04:51 PM   #10
Rewards Points: 6,652
Check Discounttire.com or Tirerack.com for this info. Also the sticker on the side of the door, or the owner's manual will state the sizes that the manufacturer recommends for the vehicle.
Old 04-20-2013, 06:12 PM   #11
Rewards Points: 582
thanks for all the good advice ..problem solved as I thougth ..made him put same size tire and wheel back on truck..ben sr
Old 05-03-2013, 08:05 AM   #12
Mold!! Let's kill it!
Rewards Points: 2,012
Probably the smartest move. The 17" version is only an inch bigger outside diameter, but my experience has been 17" tires are more expensive.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
ben's plumbing (05-03-2013)
Unladen condition, with tires on the ground? Bigplanz Automotive Repairs 5 11-28-2012 05:34 AM
Electric Trailer Brakes and Tires Condition Questions DIYguy2000 Automotive Repairs 10 09-18-2012 08:15 AM
Pressurizing car tires flyinghigh Appliances 5 02-13-2012 03:24 PM
Wobbling after new tires spaceman spif Automotive Repairs 24 10-11-2010 10:19 PM
Small pneumatic tires not holding pressure Nestor_Kelebay Automotive Repairs 14 04-26-2009 08:39 AM
