Tire Mounting - Automotive Repairs - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-02-2011, 04:45 PM   #31
Toronto, Ontario Canada
Audiotekm is offline   Reply With Quote
Old 10-02-2011, 05:49 PM   #32
Rewards Points: 252
Makes sense then, my apologies.
I moderate a couple of car forums and we have a large Canadian contingent. I think most of them have adapted to wheel instead of rim terminology. I have been in Canada many times (Markham) in one of my previous roles. I love the Toronto area.
Marty1Mc is offline   Reply With Quote
Old 10-02-2011, 10:07 PM   #33
Regarding the ratchet strap trick. How tight do I get the strap on the tire?
Old 10-03-2011, 04:55 PM   #34
Rewards Points: 252
I would do it until the tire buckles and pulls away from the bead. You may even need a second strap to put around as well to continue where the 1st one runs out.
Old 10-07-2011, 08:37 PM   #35
I just noticed that there's 2 little dents on the rims, I probably made them when I installed the tire. Can that be an issue??
Old 10-10-2011, 04:46 PM   #36
dents in wheel
Should not be a problem, as long as the tire is not leaking where the dents are in wheel. Aluminum or steel ?? tire should be balanced after installing to provide a smooth ride at higher speeds.
fkoz is offline   Reply With Quote
Old 10-10-2011, 05:07 PM   #37
Steel rims. Another interesting thing... One of the tire that had a flat hasn't lost a pound of pressure yet. It's a winter tire and got a flat on it last spring. I tried to find the hole with soapy water but couldn't find it. I finally set the bead with ether and got the tire to 40psi for over a week now and it's still at 40psi!!!!
Mounting to Garage Ceiling stacyjkcmo Building & Construction 12 05-18-2011 04:14 PM
2009 Montana Van tire warning Wildie Automotive Repairs 10 12-06-2010 05:44 AM
Mounting Checkolite pot rack with lighting Warner Electrical 2 06-16-2010 01:56 PM
Toilet leaking from seat mounting hole jrpoole59 Plumbing 11 05-05-2010 10:25 AM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 04:26 PM
