Tips For Replacing Front Wheel Hub, 1991 Toyota Corolla - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-27-2013, 12:03 PM   #1
Tips for replacing front wheel hub, 1991 Toyota Corolla
Hey folks,
So I went out to do my brakes this morning, and find out one of my lug nuts is cross threaded. But I needed to do my brakes! So I kept trying to get it off, and broke the lug stud. Can't seem to get the old stud out, using a propane torch and a hammer, so I've decided to just replace the wheel hub. Bearings are still good so I don't need the entire assembly.
It looks like a pretty straightforward job, but does anyone have some pointers to offer? Thanks!
MFToast is offline   Reply With Quote
Old 03-27-2013, 12:32 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
With a big hammer and punch or steel rod that stud will drive out the back. It is pretty straight forward to R&R the hub.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 03-27-2013, 09:35 PM   #3
ukrkoz's Avatar
Rewards Points: 930
I have broken many and have never seen one that can not be driven out. With that said, you may have hub that has studs backed by bearing. Dumm design, but it is what it is.
1. You'll need to break loose center drive axle nut. THAT is not a job for weaklings. Power tool or a very long cheat bar. Plus, special socket. You can rent free "front end socket kit" from say O'reily.
2. Easier is to drive to any close by tire shop, ask them to pop that nut loose for you with power tool, then hand torque it back so that you can drive home and hand handle it. But you'll need to come back and have them hit it with impacy wrench again after done.
3. You'll need to disconnect tie rod end and ball joint, along with strut.
4. Make sure you have CV joint somehow secured together at the boot. They easily separate and you do not want that. Absolutely spray splines liberally with Quick Wrench or equivalent. Then have drive axle tied to something sturdy so that it does not fall down and apart.
ukrkoz is offline   Reply With Quote
Installing new front door...... Any tips ????? ogoz23 Remodeling 32 05-13-2012 11:10 PM
Front yard landscaping tips beginner1 Landscaping & Lawn Care 9 02-04-2012 01:00 AM
Front yard decorating tips jay_chua Landscaping & Lawn Care 1 03-10-2010 08:00 AM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 07:31 AM
thin film of oil on left front wheel bobo Automotive Repairs 15 04-11-2007 08:24 PM
