Tips For Changing GM 3.8 Spark Plugs???? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-16-2014, 06:37 AM   #1
Rewards Points: 274
Tips for changing GM 3.8 spark plugs????
Anyone have any tips or "secrets" to changing the back three plugs on a Buick Lucerne 3.8? Or is is just a couple of hours of pure frustration, skinned knuckles, swearing, and a lot of booze? It sure looks like that will be the situation. Thanks.
polarzak is offline   Reply With Quote
Old 04-16-2014, 06:58 AM   #2
Hogger
I believe that you pretty much have it figured out! The Jimmy and Blazers are pretty much the same way from what I was told. Good luck and post your progress.
DH558 is offline   Reply With Quote
Old 04-16-2014, 08:52 AM   #3
Rewards Points: 13,300
The engineers that design these things should be made to do all the basic mantaince items on a vehicle before passing that B/S on to customers.
I've found a universal adaptor helps.
http://www.sears.com/craftsman-unive...p-00904435000P
I also use the shop vac once the plugs out to suck up any trash around the plug hole before installing the new plug.
Old 04-16-2014, 09:31 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,940
No secrets.
Busted knuckles is all.
Old 04-16-2014, 06:12 PM   #5
Get the thexton engine mover. When I changed plugs in my daughters 3.1 v6 lumina , I removed the dogbones and inserted thexton and cranked engine forward. Google thexton engine mover.
toolaholic is offline   Reply With Quote
Old 04-16-2014, 10:12 PM   #6
Try doing it on a 4th gen Camaro V8.
We got so used to doing it that we just drop the motor.
Old 04-17-2014, 10:25 AM   #7
raylo32's Avatar
Rewards Points: 1,240
Indeed, I have on my 1994 LT1! It takes several hours, many busted knuckles, and some serious creativity just to get #2 plug! Some of the others alls you need to do is drop the exhaust. Any way you slice it takes about a good solid day.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 04-17-2014, 02:50 PM   #8
Oso954's Avatar
Rewards Points: 766
Try spraying some PB Blaster on the threads, and let them soak a bit. That should help.
When you go to reinstall them, put some hi temp anti seize on the threads. Then torque them. A lot of people over tighten spark plugs.
They will come out a lot easier next time.
My vote for the worst car for plug changing goes to the Shelby GT500. You could fight them, but it was easier to pull the engine.
Oso954 is offline   Reply With Quote
Old 04-17-2014, 03:14 PM   #9
I had a 4 cat 1996. They were the worst of the LT1 era cars but I feel you pain my man.
Unsuccessfully Changed Spark Plugs sweaty Automotive Repairs 16 04-01-2014 09:45 PM
Spark plugs seizing on high mileage engines:myth or fact? toolaholic Automotive Repairs 18 11-13-2012 12:39 PM
Inspecting spark plugs in a high mileage car Bigplanz Automotive Repairs 16 07-18-2011 07:28 AM
'06 Impala - how to change spark plugs + gap spec. DIYguy2000 Automotive Repairs 0 06-20-2011 10:26 AM
Spark Plugs rusty baker Automotive Repairs 13 08-30-2009 09:09 PM
