Time For A Battery? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-06-2012, 05:18 PM   #1
Rewards Points: 320
Time for a battery?
2007 Honda Accord. I was at the dealer a while back and they did multi-point inspection. They rate everything in colors so the battery was in the yellow and the description read that it was just okay not good which would have been green. I did my own load test with a battery load tester this past summer and it also confirmed that it was at the low side of good. This morning I forgot to shut off the headlights and was sitting with the engine off for about 20 minutes. I went to start the car and it was dead. Is 20 minutes too short to have caused it to die. I don't mind replacing the battery if necessary but I also don't want to throw it out if it has another year(s) of life in it. Time to replace it?
teamo is offline   Reply With Quote
Old 12-06-2012, 05:56 PM   #2
Rewards Points: 14,290
In your area as cold as it gets and two differant test suggested it's no good, hmm. Time for a new one.
Old 12-06-2012, 06:18 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 180
If any doubt, take it to an auto parts store or Walmart. They usually test them for free.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-06-2012, 06:22 PM   #4
Most auto supply stores will even change it for you free.
Old 12-06-2012, 08:26 PM   #5
Rewards Points: 258
to charge it just drive for an hour or so. but if its dead it could fry your alternator with it trying to charge.
redman88 is offline   Reply With Quote
Old 12-07-2012, 06:23 AM   #6
Rewards Points: 180
That's not true. It won't hurt your alternator.
Old 12-07-2012, 06:51 AM   #7
47_47's Avatar
Rewards Points: 74
6 years old, two tests show marginal, change it.
47_47 is offline   Reply With Quote
Old 12-07-2012, 11:20 AM   #8
To me it is time for a new battery when I DO NOT leave the lights on, everything on the vehicle is working normally, but then suddenly on a cold day the battery does not have enough power to start the vehicle (will not hold a charge).
If I leave the lights on, then charge the battery, then it starts the vehicle ok after that, then no need for a new battery.
The battery is just like one in a cell phone. If you use the cellphone and run down the battery, you need to plug it in and recharge it.
Same with a car. If you leave the lights on without the vehicle running, then you need to recharge the battery - either with a car battery charger or by jump starting and leaving the vehicle running (alternator recharges the battery).
Billy_Bob is offline   Reply With Quote
Old 12-07-2012, 11:51 AM   #9
47_47's Avatar
Rewards Points: 74
He needs a battery. He said he left the headlights on for only 20 minutes. Would you not change your cell phone battery if you had to recharge it after every few calls and it is 6 years old?
Old 12-07-2012, 02:09 PM   #10
Rewards Points: 180
Could also be the alternator. Why not just take the battery for a free test and know for sure?
Old 12-07-2012, 04:53 PM   #11
Rewards Points: 304
Could be the battery, could be the alternator. Run the car at idle, and see what the altenator is putting out. Put all accessories on, and it should be putting out 13.5 or thereabouts. If it is, it is not the alternator.
And like Rusty says... a dead or going dead battery will NOT hurt the alternator.
Take it to one of those free battery test places and ask them to do a load test.
Batteries are strange. MY brand new 2000 Buick LeSabre had the original battery when I traded in, in 2007...seven years no problems.. My then new Buick Lucerne, had the battery replaced under warranty after 17 months.
Frankly, I know everyone is not in my position, but I would just go buy a new one. Nothing is more frustrating, and dangerous in the cold, than a car that won't start. Been there with all the junk I used to drive in my youth.
polarzak is offline   Reply With Quote
Old 12-07-2012, 09:36 PM   #12
Missouri Bound's Avatar
Replace the battery. It's extremely lucky to have a battery last 5 years, let alone 6. Is it worth getting stranded to save a few dollars? Get your batttery from a battery distributor or an auto parts store. Dealers will double the price.
Do you want it your way or the right way?
Old 12-07-2012, 09:52 PM   #13
3 years or more replace the battery for sure. Easy way to test the alternator, while the engine is running disconnect a battery cable, if the veh stalls the alternator is bad.
Hardway is offline   Reply With Quote
Old 12-08-2012, 09:30 AM   #14
Two tests already showed the battery going weak, I would suggest replacing with a new decent quality battery. The cold weather on the way will just work that battery even harder, not worth needing a jump start or tow just to save a few bucks.
Do not do this on a newer car, disconnecting a battery with the vehicle running can cause a voltage spike and fry your cars computer, not very common to happen but it is possible.
D-rock is offline   Reply With Quote
The Following User Says Thank You to D-rock For This Useful Post:
rusty baker (12-08-2012)
Old 12-08-2012, 02:22 PM   #15
"That said, removing the battery while the engine is running is not recommended for modern vehicles as the battery does play an important role in surge suppression by absorbing current spikes and if you run a vehicle without a battery for an extended period of time you put extra strain on the voltage regulators within the vehicle's electrical system. In older vehicles that used carburetors and did not have computer controls removing the battery was fine, but it's generally not recommended for modern cars."
Hind sight I did not consider the new veh with all the computers and such. I stand corrected, I guess it is time to get a new vehicle.
Can I mix different CCA battery ratings? Red Squirrel Electrical 9 05-11-2012 06:58 PM
Kidde Smoke Alarm Battery Replacement e-Andy Electrical 0 12-29-2011 12:32 PM
generator battery trickle charger veretiL Electrical 5 09-08-2010 05:51 PM
Trickle charger on portable generator - bad battery? timp Electrical 5 01-01-2009 07:46 PM
Battery Problem sweaty Automotive Repairs 11 12-15-2008 06:32 PM
