Threadlocker For Shock Absorber Bolts - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-17-2013, 04:53 PM   #1
Hi I am going to be putting KYB monomax shocks, front and rear, on my 99 Dodge dakota R/T next week. The Haynes book says I have to put threadlocker on front shock bolts. Torque is low at 19 and 20 lb feet. I purchased permatex 27100 high strength red thread locker. It says on package it is good for shocks.If I need to remove shocks in future, will this make removal difficult.? I know removing factory front shocks sometimes causes front shock bolts to break. Is this caused by threadlocker applied at factory? And yes I have breaker bars; I would use my 18" 3/8 drive harbor freight or a 15"(craftsman) 1/2 drive or 24" (gearwrench) 1/2 drive. Going from shortest to longest til bolts broke free. I will also use krol or Gibbs penetrating oil.
toolaholic is offline   Reply With Quote
Old 01-17-2013, 05:07 PM   #2
Rewards Points: 131
Do not use the red, which is what you have, as it's the "heat to release" type.
Get/use the blue ( 24200 ).
Or feel free to use it ( the high strength ), knowing that you'll probably snap the bolts next time you attempt to take them off.
Chokingdogs is offline   Reply With Quote
The Following User Says Thank You to Chokingdogs For This Useful Post:
toolaholic (01-18-2013)
Old 01-17-2013, 05:15 PM   #3
Rewards Points: 13,296
I've never snapped a bolt off when changing shocks, if you do it's because of rust.
I agree blue is the way to go.
Old 01-17-2013, 05:51 PM   #4
According to the Dakota forums they have a tendency to break. One of them listed the size znd thread count(can't think of it off hand) and said to get grade 8.
Old 01-17-2013, 05:53 PM   #5
It's a 99 w/ 50,000 original miles. Last set of shocks it will see til it goes to dodge land in the sky.
Anchor bolts not sitting properly in wall HandyCapped Concrete, Stone & Masonry 3 04-15-2012 09:15 AM
Front loader washer transport bolts Richo Appliances 2 11-03-2010 12:59 AM
Concrete for fence gate cane bolts? jpearson311 Building & Construction 3 06-17-2010 10:13 PM
Leaking tank bolts splinters Plumbing 4 12-25-2009 07:04 PM
galvanized bolts for pressure treated wood? Jeremy Hillary Boob, PhD Building & Construction 11 07-10-2009 10:53 AM
