Thermostat Is Bad - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-18-2010, 09:00 PM   #1
thermostat is bad
How much is involved in installing a new thermostat in my 2000 Ford Ranger?
How long is it safe to drive with symptoms of a bad thermostat?
grumpdog is offline   Reply With Quote
Old 05-19-2010, 12:10 AM   #2
Oldguy
Rehabber's Avatar
Which engine is in your ranger?
Are the 'symptoms' for a stuck open or stuck closed thermostat?
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 05-19-2010, 09:38 AM   #3
Engine is 4. something? v6. Stuck closed. thanks
Old 05-21-2010, 07:16 AM   #4
Rewards Points: 129
found this. I wouldn't go by the part numbers on this web link becasuse they might not match yours.
http://www.explorerforum.com/Singlet...hermostat.html
bigcaddy is offline   Reply With Quote
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 05:37 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 09:21 AM
