Thermostat? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-23-2009, 12:10 PM   #1
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Thermostat?
89 Buick Riviera v-6. Drive for hours on the hiway, temp stays normal. Let it sit and idle it overheats. Drive in stop-and-go traffic and it overheats. Would you change the thermostat first and what temp would you use?
Old 07-23-2009, 12:43 PM   #2
47_47's Avatar
Rewards Points: 44
I'd check the engine cooling fan first. Does it come on? For thermostats, install 190-195.
47_47 is offline   Reply With Quote
Old 07-23-2009, 01:25 PM   #3
Rewards Points: 42
Yes the cooling fan comes on.
Old 07-23-2009, 01:41 PM   #4
47_47's Avatar
Rewards Points: 44
For the cost, I'd replace it, but don't think that's the problem. Usually, when a thermostat sticks closed the car will overheat all the time. I'd look for a restriction of the air flow over the rad, slipping belt...
Old 07-23-2009, 08:36 PM   #5
Agreed, check your belt tension. The force of air and volume at hiway speed eliminates the need for the fan itself. At low speeds the fan is not acting effectively, so satrt there
Chemist1961 is offline   Reply With Quote
Old 07-23-2009, 09:18 PM   #6
Rewards Points: 42
The car has an electric fan.
Old 07-27-2009, 11:38 PM   #7
and the cooling fan is coming on while its sitting? Does it overheat while the fan is on? Do you have a way to take the temperature at the thermostat (laser thermometer or such)? Could be the gauge is off, or the fan is cutting out while it gets hot.
Scrufdog is offline   Reply With Quote
Old 07-28-2009, 08:46 AM   #8
Has the cooling system been flushed,sounds like maybe a restriction in the system,so at idle the flow is slowed and gets hot,feel the radiator from top to bottom and side to side is there cold spots?if flushing is needed Pematex makes a strong flush think the part number is 811,
gotboost is offline   Reply With Quote
Old 07-28-2009, 08:54 AM   #9
Rewards Points: 42
Taking it to a mechanic tomorrow. Think the temp sender is not turning the fan on at a low enough temp.
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 11:07 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 10:21 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
