Temperature Gauge Stopped Reading - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-13-2011, 11:00 AM   #1
Temperature gauge stopped reading
My wifes car's(2001 chevrolet impala) temperature gauge on the dash panel has stopped reading, just shows that the engine is below the cold line constantly..and has caused the check engine light to stay on....suggestions/solutions please? Thanks.
JohnDeereGreen is offline   Reply With Quote
Old 01-13-2011, 11:17 AM   #2
Experienced
Jackofall1's Avatar
Don't know where you are at, if has been real cold you may have a frozen cooling system, get it into a warm place, but if it is frozen chances are the damage is done. I wouldn't run it until you verify that the cooling system is not frozen, otherwise you will cause alot more damage.
Old 01-13-2011, 11:37 AM   #3
Could be...but there is coolant in the radiator and both the heating and ac work in the car....could it be an air bubble in the radiatior thats causing the gauge not to read?
Old 01-13-2011, 12:05 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,728
Ayuh,... I'd sooner think the temp sensor, or it's wiring is the problem...
Bondo is online now   Reply With Quote
Old 01-13-2011, 12:13 PM   #5
Experienced
Jackofall1's Avatar
The fact your heater works would tell me that your sensing unit is bad or the connection to the sensing unit.
Old 01-13-2011, 02:17 PM   #6
Arite thx...any tips on checkin to see if the sensor has **** the bed?
Old 01-13-2011, 02:52 PM   #7
Experienced
Jackofall1's Avatar
I don't know of any tests, they are only about $10 and the local auto parts store.
Old 01-13-2011, 02:56 PM   #8
Arite well I appreciate your help..ill try that out
Old 01-13-2011, 05:16 PM   #9
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
You could bleed the cooling system easy enough to release trapped air ( if any). There should be directions in your manual, but you basically remove the rad cap, then loosen the bled screw that directly over the thermostat and run the engine ( with the heat turned on) until you get fluid coming out. Let it run for a second, then tighten the bleed screw. Top of the antifreeze and put your rad cap back on.
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 01-13-2011, 06:16 PM   #10
Arite ill give it a shot..thx
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
pressure gauge reading for natural gas line robismyname Plumbing 5 10-13-2010 08:39 AM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
how to stop condensation on windows? cake General DIY Discussions 7 11-22-2008 12:12 AM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
