Temperature Control Sensor - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-14-2009, 10:51 AM   #1
Temperature control sensor
I have a 2000 Ford Ranger with over 150,000 miles on it. Last week on the way home, I noticed that the temperature gauge was buried in the high. It was a very cold windy day and I was getting no heat. I pulled over and called my husband. I noticed after I pulled over and put in in park that the temperature gauge went back down to c. My husband came and check the fluids. Everything seemed to be in order but he did add some more coolant. He drove it home. It went up to H one more time but then leveled out and he had heat. We had a shop replace the thermostat. But the truck is still doing the same thing. What else could the problem be besides the temperature control sensor?
Rindyrae is offline   Reply With Quote
Old 12-14-2009, 03:02 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,... A Blown Headgasket will do that...
It'll over pressurize the cooling system blowing out the fluid...
The cabin heater is the 1st place in the system to loose fluid, being the highest, hence, No heat...
If it were the cabin heat water control valve, the Temp Gauge wouldn't show any changes,...
You have a motor overheat situation, which is causing the loss of heat...
Is the fluid level changing in the reservoir,..??
Look for signs of antifreeze in the tailpipe/ exhaust stream...
Old 12-15-2009, 07:48 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 56
Check the oil? If it has a white, milky look, you have a blown head gasket, a cracked head or a cracked block.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-28-2009, 04:30 PM   #4
I agree with bondo. Even if your head gasket wasn’t blown, it likely is now after overheating the engine.
I would start by checking the oil for water. Next check the coolant for oil. Lastly perform a compression check. Also hold a rag over the tail pipe for a few minutes. Rev the engine a little bit. (just a little bit) remove the rag. Small the rag. Does it have that sweet antifreeze smell to it? you can also use a 5 gas analyzer held over the coolant overflow bottle to see it you can detect exhaust gas coming from the coolant bottle. I doubt you have that tool, but a well equipped garage would.
Why did you replace the thermostat? Was the engine overheating? Overheating an engine will cook the head gasket, so if it wasn't chowder before, it likely is now. Especially if it was overheated more than once.
zackinma is offline   Reply With Quote
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 23 11-05-2014 01:36 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Need HELP swapping a Vision pro 8320u1008 to an IAQ one N01B4ME HVAC 161 01-10-2011 03:30 PM
how to stop condensation on windows? cake General DIY Discussions 7 11-22-2008 01:12 AM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
