Tcs - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-27-2013, 11:08 AM   #1
Rewards Points: 109
Tcs
I have a 2008 Impala, The TCS activates for no reason.can someone tell me why?It happens when you pull out ( no icey or wet conditions) If its the sensor ,How can you tell which one to replace? thanks
lemley98 is offline   Reply With Quote
Old 10-27-2013, 02:25 PM   #2
Rewards Points: 254
Sounds like an erratic speed sensor. You will need to watch each sensor with a scan tool to see which one drops out. Unless it failed long enough to set a code. It usually will not if it only drops at low speed the computer just thinks the wheel is slipping.
cjm94 is offline   Reply With Quote
Old 10-27-2013, 06:44 PM   #3
Rewards Points: 109
Are the sensors only on the front wheels? Would it be wise to buy one and try on each wheel, to see if that cures the problem? thanks
Old 10-27-2013, 07:20 PM   #4
Rewards Points: 254
No they are on all 4. Not sure on 08 impala not all are service separate from the wheal bearing. It will be cheaper to have someone diagnose it than just throwing parts at it.
Old 10-27-2013, 07:49 PM   #5
Rewards Points: 268
Absolutely correct. Have somebody diagnose it then replace it yourself if you like. 08 Impalas have them built into the bearing hub assemblies. Very common issue.
Marqed97 is offline   Reply With Quote
Old 10-27-2013, 09:47 PM   #6
Remodeler
Rewards Points: 324
Could also be the wiring harness running to the sensors, these often fail on the front wheels due to the wire repeatedly bending as the front wheels are steered back and forth over the years.
Changing the wheel bearing/hub assembly is not too difficult if you do much auto work. The job often generates significant profit for the shop; many of which seem to do little more than just throw the parts at it for you.
iamrfixit is offline   Reply With Quote
Old 10-28-2013, 07:57 AM   #7
Rewards Points: 2,638
Are all your tires the original size? If the tires were designed to be all the same size, and you swap out one or more tires to different sizes, the computer will "see" some wheels running at a different speed than the others, and may interpret this as a wheel spinning.
SPS-1 is offline   Reply With Quote
Old 10-28-2013, 11:00 AM   #8
47_47's Avatar
Rewards Points: 58
Are you getting wheel slip (worn tires)?
47_47 is offline   Reply With Quote
Old 10-29-2013, 11:06 PM   #9
Definitely one to diagnose rather than spin the wheel of parts, not too difficult to isolate a wheel with a scan tool and multimeter, but harness vs sensor can be a tossup, and proper splicing is critical with the harness repair.
Lotek is offline   Reply With Quote
Old 10-30-2013, 07:05 AM   #10
Will any check engine light ever come on?
davey68 is offline   Reply With Quote
Old 10-30-2013, 09:17 AM   #11
No, not a driveability issue. ABS/TCS ligght will come on eventually, but if you can duplicate the concern, it should be fairly easy to isolate the wheel with a scantool during a roadtest.
Old 10-31-2013, 06:14 AM   #12
47_47's Avatar
Rewards Points: 58
To the op does the ABS light come on and stay on? If your ABS is working correctly, the problem cannot be a wheel speed sensor or wiring to the sensor.
probable causes (in order):
worn front tires
hard acceleration causing slip
bad tcm / bcm
Old 10-31-2013, 06:30 AM   #13
Rewards Points: 254
[QUOTE="47_47"]To the op does the ABS light come on and stay on? If your ABS is working correctly, the problem cannot be a wheel speed sensor or wiring to the sensor. probable causes (in order): worn front tires hard acceleration causing slip bad tcm / bcm[/QUOTE.
Incorrect a bad wheel wheel speed sensor that only drops out at slow speeds will cause this and is very common. I see a couple a month.
